ECM constants ????
Old Sep 24, 2003 | 05:38 AM
Lisa33's Avatar
ECM constants ????
Have a big problem. after i change a parameter in the ECM constants table ( fuel cut off mph, max line pressure or fuel cut off1 2-6 gear) the car wont run its only firing up for a sec and dies, After loading the "stock" file again it runs ok. have tried it on 2 cars and having the same trouble on both. Its no problems when i change in another table....
Proberbly something i have missed but i cant figur out what it is.
Old Sep 24, 2003 | 11:01 AM
radik's Avatar
I've done silly things before like changed my injectors to 4lb's , start with the file that works and make your changes over again.
Old Sep 24, 2003 | 01:57 PM
Lisa33's Avatar
Its not that i have done anything wrong, i have loaded my "stock" file again an the car runns fine, after that i raised max line pressure in the ECM constant table to 105 (that was the only change) and saved the file in another name and then programed the pcm and the car wont start again . loaded the stock file and it runs again . did the same thing on another car and only lowered the fuel cutoff 1 gear and the fuel resume 1gear (1 step)and the car only run for a second reloded the "stock" file and everythings ok.
Have also made changes in other tables without any problems.
Also noticed another funny thing my injector settings are 2538,00 Thats big. after i did a litle search find that it could be the eeB def file i needed so i try to open my file whidh eeB and wow no my injectors were 236976,00 so that wasnt the trouble, have download a couple of bin files from internet and the all shows BIG injectors doesnt matter if open them in ee or eeB
Beginning to think that something is wrong with my Definitonfile
Any ideas?
Old Sep 24, 2003 | 02:04 PM
madwolf's Avatar
Check to make sure you're using the right definition file. Take a look at your injector constant to verify this. If it's ~24.xx then you're working with the right DEF. If not, then you have to switch to the other one. (EE/EEB)
Old Sep 24, 2003 | 02:08 PM
Lisa33's Avatar
Was editing my replay whn you wrote your
Madwolf can you test my def file if i mail it to you?
Old Sep 24, 2003 | 02:21 PM
madwolf's Avatar
You can't just email me the definition file. They won't work like that.
I'd try contacting TC at tc@tunercat.com and ask him what he thinks about this. He's very helpful and usually answers quick.
Old Sep 24, 2003 | 02:26 PM
Lisa33's Avatar
I have alredy malied him and his first ide was the eeb but it seems like its another problem...
Why is it i cant mail the file. TC mailed it to me.... i asumed you alredy have a copy? if you dont have it i understand that i not should mail it to you...
Old Sep 24, 2003 | 02:28 PM
madwolf's Avatar
Oh yes, I do have the copy, and yes, if you send me the exact same thing TC sent you, that will work, but if you send me the files after you unarchived them, then they won't. (sort of a protection thing) It will ask for a password I don't know.
Anyway, if TC sent you the stuff, I'm sure it works. Try installing Tunercat on a different computer and try editing the file again.
Old Sep 24, 2003 | 02:50 PM
Lisa33's Avatar
Hmmm I recived the mail to my computer at work and at that time i had lot of files (70-80mb) that i should bring home so i loaded them to my camera and uploaded them at home (i work 2 weeks and are free 4 weeks) Maybe something went wrong there...
I will wait for TC answer and se what he suggest...Was thinkin that someone had been true this and could give me a quick answer....
Old Sep 24, 2003 | 02:54 PM
madwolf's Avatar
Well, the quick answer that normally works for everyone is to switch the definition, but you seem to have a different problem, so I say just reinstall the thing. You can download the latest tunercat from their website. It's a full version once you give it your serial number.
Old Sep 25, 2003 | 11:28 AM
Lisa33's Avatar
No the problem is solved..
Had to change the setup in my computer so it uses . insted of , between numbers. 1,1 is the normal way to write in europe but not usa.
Simple when you no it
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
greenzee28
Sep 25, 2015 04:29 PM
frankrizz
Sep 23, 2015 04:21 PM
marlar98
Sep 19, 2015 07:53 AM
