does this make any sense
Old Oct 29, 2009 | 12:39 PM
9sevenZ's Avatar
i just put a holley 52mm throttle body on my car (used)..already had a new IAC valve and i just left the TPS sensor that it had on it already. car shifts much softer now...when i had it tuned i had Ion adjust to make the shift a little harder and i loved it ..but now i put that holley on there and it shifts softer. Would changing the TPS sensor make it shift differently (softer)? i figure that can be the only thing that would make it do this.
Old Oct 30, 2009 | 03:49 PM
AJ52486's Avatar
You probably aren't pressing the gas pedal as far, because the bigger TB flows more air at the same position compared to a stock TB.
Since the transmission tables are based on TPS, the shift points and firmness are affected.
I didn't do the transmission tuning on my car, so I can't give you step by step instructions. I believe there is a transmission tuning tutorial on this site.
Old Oct 30, 2009 | 05:03 PM
LearJet's Avatar
AJ52486 hit the nail on the head.
Old Oct 30, 2009 | 06:50 PM
9sevenZ's Avatar
thx guys so if i want it firmed back up i would have to get it re-tuned correct?
Old Oct 30, 2009 | 09:28 PM
AJ52486's Avatar
Correct. Your tuner would have to shift the values in the transmission tables so the car behaves like it did before, but at a lower TPS value. I'm sure your tuner will know what to do. If not, maybe I can give you a better description of what needs to be changed.
Old Oct 30, 2009 | 11:54 PM
9sevenZ's Avatar
Thx AJ
Old Oct 31, 2009 | 04:53 PM
sbs's Avatar
sbs
First thing to do is verify that your TPS is working right.
Old Oct 31, 2009 | 11:13 PM
9sevenZ's Avatar
gonna do that tomorrow, .20-.90 acceptable right? gona shoot for .67 closed and no more than 4.9 WOT, will let u know the results.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jasonduaine
Mar 7, 2015 09:44 AM
InfernalVortex
Jan 17, 2015 09:35 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
