Do I need to get my shift points reprogrammed with a high stall?
Old Feb 20, 2004 | 02:47 PM
slider's Avatar
I'm putting a 3500 stall in shortly. Should I have my shift points reprogrammed? If so, what should they be changed to?
Motor is stock. Car just has bolt ons.
Old Feb 20, 2004 | 11:33 PM
Hal Fisher's Avatar
I don't have a high stall but if I did I would let my butt be my guide.
Hal
Old Feb 21, 2004 | 08:50 PM
Dan K's Avatar
Installing a looser converter should not impact your ideal shift points since it doesn't change your powerband.
Only thing you might have a problem with is the no 1-2 shift.
Old Feb 22, 2004 | 12:27 AM
AL SS590 M6's Avatar
Moderator
It will depend upon how loose the converter is. Sometimes the extra slip of a high stall can cause you to hit the rev limiter before the mph of the shift point. If it doesn't then you're OK.
Old Feb 22, 2004 | 06:15 PM
Dan K's Avatar
That would require one loose converter!
Old Feb 22, 2004 | 06:23 PM
97Z-M6's Avatar
i had a 4000 stall running great and without a problem and was pretty good as a daily driver. it was surprising how good it work after hours of tunning
Old Feb 23, 2004 | 02:20 AM
Moderator
Not that kind of loose I'm talking about efficiency at WOT in the upper rpm ranges.
Say that the stock converter is 95% efficient at 6000 rpm netting 42 mph. If an aftermarket converter was 90% efficient then 6000 rpm would only net 40 ish mph and you'd hit the rev limiter before it would shift.
Like I said: If you don't hit the limiter on shifts then you'll be fine without programming.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Dec 28, 2014 09:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
