Do I HAVE to have my pcm programed with a cam
Old Aug 29, 2002 | 11:22 PM
2ZPOINT's Avatar
Post Do I HAVE to have my pcm programed with a cam
OK... after fixin a problem with the opti the car still runs like ****. I just put ported heads and a new cam in it. I was told that my stock programing would work, but I just would not see full benefits of the mods until a reprogram. I know people do this with the HC and the 305,but my cam is bigger. (224/236 .503/.521 114) Do I have to have tha reprograming done to drive it. The car misses (and sometimes backfires) badly when I drive it. It sounds like the ignition to me, but then I thought about the computer being out of wack. Also does the computer control the fuel pressure. I am still running stock fuel pressure. I am lost here.
Old Aug 30, 2002 | 12:55 AM
Hal Fisher's Avatar
Post
That does sound like an ignition problem. A reprogram would only be for too rich or lean but cruising should not be a problem.
Mine always needs the connecters on the opti messed with once or twice to get a good connection there. If you have an aftermarket box take if off and see what that does.
I have seen others with similar problems on the lt1 board. Do a search on it with like "missing" or "backfire". Who did the cam install?
Hal
[This message has been edited by Hal Fisher (edited August 31, 2002).]
Old Aug 30, 2002 | 03:44 AM
2ZPOINT's Avatar
Post
ttt and I did the cam...its installed correctly...the problem has to be ignition or computer,but it doesn't throw codes.
Old Aug 30, 2002 | 06:43 PM
2ZPOINT's Avatar
Post
ttt
Old Aug 31, 2002 | 03:28 AM
2ZPOINT's Avatar
Post
Anyone....someone out there has been here.
Old Aug 31, 2002 | 10:56 AM
bad95z28's Avatar
Post
I'm going to say that you have a cracked plug, bad wire, arcing wires, or maybe even the timing chain a tooth off. It does not sound like programming. Your programming will pick you up a lot of power and eliminate cam surge but if you're missing than its most likely ignition.
Black 94Z A4 t-tops
324rwhp/316rwtq (before new mods and better tuning)
The Z
Old Aug 31, 2002 | 12:52 PM
NVMYZ28's Avatar
Post
Your car will run fine without a reprogram w/ a cam swap. May not run the best - but it will run.
Your problem is going to be mechanical or electrical.
Check your valve adjustment and your opti'spark installation.
Its really hard to troubleshoot a problem of this sort over the internet. Its like diagnosing a heart problem while you are talking to the doctor on the phone.
If your still having this problem - include as many details as possible.
Jeff C - Utah
1994 383 Z28 M6
Bored, Stroked, Splayed, and Sprayed!
www.nvmyz28.com
Utah F-body Assoc.
Old Sep 7, 2002 | 04:57 PM
supercharged94Z28's Avatar
Post
Well, just giving ya my 2 cents here. I had a consistent problem with stumbling, bogging, and rough riding at all rpms. Although I did have my whole engine replaced and an aftermarket cam (lunati) installed with no programming. Car ran 50% faster than ever until it started the bogging, stumbling thing again once I drove it for 5 min. So I don't think your computer would need to be reprogrammed for your problem, although there is a first for everything right? Good luck
nikolt1
Feb 27, 2015 09:10 PM
CARiD
Jan 27, 2015 06:27 AM
Injuneer
Dec 15, 2014 09:36 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
