Did I pop my computer?
Old Aug 20, 2007 | 11:32 PM
sam pace's Avatar
I finally got my car running a while back and have been doing the slow task of fine tuning the car. Yesterday I set the tps sensor to the set level of .67 volts with a volt meter. While I was doing this, I heard some clicking and the the air pump started running on and off just like the car was warming up. The only thing was that I only had the key forward. After I set the tps, I turned the key off and unplugged the battery to reset the computer. I tried to start it up and NOTHING. The damn thing won't start. I checked the Ignition fuse under the hood and it was fine. I check the plugs and they were good (not soaked). What did I do? Did I pop the computer or is the opti fried. Or is there a fuse that I am missing. If I turn the key on the fuel pump turns on so that takes that one out and the fuel pressure is good.
I am not able to check spark and turn the key at the same time.
If you need more info let me know.
~Sam
Its a 97 firebird obdII
Old Aug 21, 2007 | 09:49 PM
sam pace's Avatar
**update** it has no spark
Old Aug 21, 2007 | 10:00 PM
VinceTrifecta's Avatar
Can you scan it for trouble codes? That might help us narrow it down.
Old Aug 21, 2007 | 11:59 PM
sam pace's Avatar
No codes, I can't get it to start for codes to appear.
I don't have a scanner only a code checker. The checker says no codes.
This one has me stumped and scratching my head.
I used this method for setting the tps sensor. http://www.golenengineservice.com/html/tps.html
Old Aug 22, 2007 | 06:05 PM
sam pace's Avatar
well, its not the computer.... the search continues.
Old Aug 23, 2007 | 06:15 PM
sam pace's Avatar
What kind of info do you guys need?
I am at a loss here.
So far:
new computer
new modual
all fuses are good
fuel and fuel pressure good
plugs look fine
I still have no spark.
What should I check next?
The car ran before I did the tps adjustment.
Help.
Old Aug 26, 2007 | 02:01 PM
sam pace's Avatar
Changed opti it was going bad but still no start.
Anybody?
Suggestions?
Old Aug 26, 2007 | 04:40 PM
sam pace's Avatar
coil is not it either
could it be the vats modual?
anyway to bypass it?
Old Aug 27, 2007 | 10:02 AM
sam pace's Avatar
Wiring harness on the passenger side, is there anyplace I should be looking at?
Old Aug 27, 2007 | 03:16 PM
OutKast's Avatar
Check all of connectors leading down to the opti....
Are you getting spark off the coil at all? Not off the opti..the coil itself.
Do you have an aftermarket ignition on the car? If so, try removing and running on stock ignition.
Test/Replace the ICM...
Old Aug 27, 2007 | 05:55 PM
sam pace's Avatar
No spark off the coil. ICM? That the one above the coil? if so, replaced.
Its all stock ignition.
Old Sep 2, 2007 | 10:13 PM
sam pace's Avatar
Update....
I have no power to the coil.
Where does the coil wire lead to in the harness to get power?
Old Sep 21, 2007 | 06:45 AM
pat35's Avatar
pm sent .spelling is very bad so pmed
Old Dec 30, 2008 | 08:35 PM
quicksilver97ta's Avatar
Originally Posted by sam pace
Update....
Sam, did you find where the coil gets power? I've searched and couldn't find a direct answer for 97's but I think it gets power from an ignition fuse which is powered from the ignition switch. 12V with key on, No PCM required.
97 OBD 2, I have a green wire and a tan wire to the coil. Tan wire is 12 volts.
I'm chasing an problem with mine so I'd like to know what happened.
Old Dec 31, 2008 | 12:27 AM
Check the fuse listing in your Owner's Manual. It will show you what fuse the coil is on.
