diablo tuner
Old Oct 13, 2008 | 11:49 AM
karpetcm's Avatar
diablo tuner
Well ive been reading up and some like it and some dont, im looking for something that i can tune myself mainly because im adding aftermarket parts one at a time, by the way this would be for a 01 Z28 6speed. I know ive heard you can adjust timing with the diablo but how much timing do you guys advance with 91 octane. I heard its one degree but not sure and some of the people ive spoken to say its well worth the money. Has anyone used the Diablo tuner and what are your experiences with it, thanks in advance for the help.
Old Oct 17, 2008 | 12:49 PM
06MonteSS's Avatar
You'd need a U7198 model Predator... http://diablosport.com/index.php?mod...display&pid=67
and since you'll be buying a new one, you'll be getting the updated versions that can now save data logs as well...
here's a list of the items you can adjust with it...
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
also, you can find a lot more info and post specific questions over on their GM Gas forums...
http://diablosport.com/index.php?nam...viewforum&f=26
GREEN3112
Feb 10, 2019 09:19 PM
fift5
11
Oct 1, 2015 10:31 AM
95_lt1_z28
Aug 30, 2015 06:17 PM
Aug 24, 2015 06:41 AM
colts0455
Jul 24, 2015 04:51 PM
