delphi/lucas inj offset vs volts (where can i get it)
Old Feb 16, 2005 | 09:42 PM
  #16
Racetronix's Avatar
Re: delphi/lucas inj offset vs volts (where can i get it)
Originally Posted by Injuneer
The offsets reflect how the injectors respond to changes in voltage. It isn't just a matter of the resistance of the winding. Its dependent on the specific design of the injector, including the mass of material that the coil has to move. The advantage of the Lucas disc is supposed to be that its low mass makes it very fast.
This also takes into consideration the resistance in the vehicle's wiring harness and the injector driver circuits etc. Constants are unique to a particular car.
Old Mar 22, 2005 | 02:19 PM
  #17
Jon A's Avatar
Anybody else try those offsets lately? Anybody had them not work?
Old Mar 22, 2005 | 03:14 PM
  #18
Seal's Avatar
worked great with mine
call me crazy, but my idle got better
Old Mar 23, 2005 | 04:50 AM
  #19
Jon A's Avatar
Cool. Injectors (along with LE3 heads) go on this weekend....
Old Mar 23, 2005 | 05:17 AM
  #20
Flyin_Z28's Avatar
Guys,
I've noticed the voltage cells in TunerCat are a little different than those listed in the link.
1 question about the celled units. TunerCat uses units expressed as usec, but the link above represents numbers differently. An example would be @ 0.00 volts "305" vs. the link's units @ 0.00 "0.23".
I am guessing by looking at the numbers, I should be multiplying those offsets by 1000 so they are reflected as the proper units. Am I right on this?
Old Mar 23, 2005 | 11:56 PM
  #21
Jon A's Avatar
That's what I'm ***uming--milisecond vs. microsecond, multiply by 1000.
Old Mar 27, 2005 | 10:10 AM
  #22
Flyin_Z28's Avatar
I tried entering those offsets but the maximum allowable value in Tunercat is 7782.
Who has entered these offsets using Tunercat?
Old Mar 27, 2005 | 04:14 PM
  #23
SMOKNZ's Avatar
Then just put in 7782. Thats what I did for mine. How many times do you drive your car under 6 Volts. My guess is NEVER!
G-BODYT56
Jan 14, 2022 11:14 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
canuck94z28
Aug 19, 2015 05:50 PM
