delphi/lucas inj offset vs volts (where can i get it)
taz showed me a link asto where i can get the chart for the delphi/lucas inj offset vs volts table, but i got a new laptop, and lost the link.... anyone know where that is?
FYI these are 42lbs
thx!
FYI these are 42lbs
thx!
Re: delphi/lucas inj offset vs volts (where can i get it)
well i found the link...
what does this exactly do? i didnt notice a single thing after i changed all the values....
all that happened was i almost broke my damn rear when i shifted lol, i heard a weird crunching noise, and then ab inop light went on lol
It changes the injector OPEN times vs voltage as you go thru the RPMs , you should notice your AF ratio curve is flatter on the dyno with the correct offsets.
Anything you described above would have nothing to do with the injector changes...unless you picked up alot of power at shift point RPM which is unlikely.
Originally Posted by Flyin_Z28
Anyone know of the offsets for the 37# Lucas injectors? It would help me out alot.
It was more of a question type statement, they just look different then others, why would a company make a set of injectors who's voltage is so far off factory? No eveidence, just that it seems unrealistic for one company to make such a dranstic change for no reason, not saying it wouldn't work, makes no difference, but wouldn't aftermarket companies base their product on a standard? beats me.
The offsets reflect how the injectors respond to changes in voltage. It isn't just a matter of the resistance of the winding. Its dependent on the specific design of the injector, including the mass of material that the coil has to move. The advantage of the Lucas disc is supposed to be that its low mass makes it very fast.
Does anyone know the injector constant and offset for Holley 42lbs injectors.
I've tried to get a hold of Holley but had no luck .
Any help would be great Clary
