Datamaster issue
Old Oct 14, 2004 | 07:39 PM
TQdrivenws6's Avatar
Datamaster issue
Hey, I just got datamaster up and running, and it logged about 20 seconds and then stopped communicating with the car computer. It did this twice, and I am wondering if this is a common problem. I am running the AKM cable, and my laptop has a serial connection that the cable connects into.
Thanks,
Chris
Old Oct 15, 2004 | 07:27 PM
Ryan94ZA4's Avatar
Re: Datamaster issue
Typically, issues like that I have experience have to do with the car. Try it on another car and see if the problem persists.
Ryan
Old Oct 15, 2004 | 10:33 PM
ZMEFLY's Avatar
Thanks,
Chris
I had the same problem. When I first installed it it was fine. Now it will only record the last 15 or 20 sec before it is stopped. WTF? I want to use it on MY car not a diffrent one. Is there a fix for this??????
Old Oct 15, 2004 | 10:34 PM
The wierd part is that a different laptop worked great logging my car...?
Old Oct 16, 2004 | 09:36 AM
Ryan94ZA4's Avatar
How much drive space is left on your laptop??
Ryan
Old Oct 16, 2004 | 10:00 AM
4.7Gb
Old Oct 16, 2004 | 12:39 PM
ZMEFLY's Avatar
Ryan
Plenty more than 7kb which is all it would record.
Old Oct 16, 2004 | 05:21 PM
jonota's Avatar
did you disable everything? no internet security, no ethernet, no running programs in the lower right corner, no infrared ports, etc?
Jonota
Old Oct 17, 2004 | 12:29 AM
ZMEFLY's Avatar
Jonota
Yep
Old Oct 17, 2004 | 05:15 AM
jonota's Avatar
Do you have it removed from it's charger while logging? IE running off battery.
Jonota
Old Oct 17, 2004 | 11:03 AM
ZMEFLY's Avatar
Jonota
LOL Yeah, I don't have an extention cord that long.
Old Oct 17, 2004 | 03:04 PM
jonota's Avatar
Some people use power inverters with their laptops (like me). Have you entertained the idea that your serial port might be kaput?
Jonota
Old Oct 17, 2004 | 06:15 PM
Alvin@pcmforless.com's Avatar
I've had this happen several times to me.
Make sure you have the IR port on your laptop disabled.
Old Oct 18, 2004 | 09:27 AM
That did it. Off to the dyno tonight
Old Oct 18, 2004 | 03:03 PM
jonota's Avatar
I thought I asked you if you turned off your infrared ports....
Jonota
MyfateZ28
Oct 5, 2015 12:36 PM
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
