data stream drops out / errors
Old Jun 25, 2011 | 09:49 PM
SkiBumDreams's Avatar
so while trying to record with datamaster and a usb cable i encounter a lot of errors / connection problems / drop outs. i can connect and record and get valid data but there are errors riddled through out the data set. here is an example
http://www.mediafire.com/?v6h5s37yj27ibek
what i am wondering is what are common causes for this?
i am thinking about tapping into the wire right outside of the pcm. would it be better to just splice into the existing wire and leave the current circuit in tact and just "piggyback" onto it? or should i cut the wire completely and go straight to my usb cable from there?
any ideas?
any help is greatly appreciated thanks
Old Jun 25, 2011 | 10:42 PM
Re: data stream drops out / errors
Did you download the .pdf of the manual? Look at page 61, 7.1.5
http://www.ttspowersystems.com/softw...32man_v400.pdf
Can be caused by poor connection, electrical interference on the data line, or unfiltered noise from a poorly grounded aftermarket ignition.
Novo
Jun 14, 2016 02:58 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
