Data logging Help
Old May 8, 2004 | 05:30 PM
supermo26's Avatar
Data logging Help
Can some one tell me what this means? And what I can do with the info as far as graph and use it for dyno info? Im new to PCM logging but I want to log my data for trouble shooting and tunning . Thanks James
08 May 04 16:20:33 - Log file has started
P: 91 - Unrecognised header
P: f0 - Header sent by ECU
P: From OnIdle - Idle Header Detected but not in Interactive
08 May 04 16:20:33 - 0xF0 0x56 0xF4 0xC6
P: 90 - Header sent by ECU
08 May 04 16:20:33 - 0x90 0x5A 0x26 0x00 0x71 0x5C 0xFF 0x24
P: 0a - Header sent by ECU
08 May 04 16:20:33 - 0x0A 0x58 0xA0 0x03 0x87 0x74
P: 85 - Unrecognised header
P: 56 - Unrecognised header
08 May 04 16:20:34 - 0x90 0x5A 0x26 0x00 0x6F 0x5C 0xFF 0x26
08 May 04 16:20:34 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:34 - 0x90 0x5A 0x23 0x00 0x6F 0x5C 0xFF 0x29
08 May 04 16:20:34 - 0x0A 0x58 0xA0 0x03 0x8C 0x6F
08 May 04 16:20:34 - 0x90 0x5A 0x25 0x00 0x6F 0x5C 0xFF 0x27
08 May 04 16:20:35 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:35 - 0x90 0x5A 0x25 0x00 0x6F 0x5C 0xFF 0x27
08 May 04 16:20:35 - 0x0A 0x58 0xA0 0x03 0xA8 0x53
08 May 04 16:20:35 - 0x0A 0x58 0xA0 0x03 0xA3 0x58
08 May 04 16:20:36 - 0x90 0x5A 0x22 0x00 0x6F 0x5C 0xFF 0x2A
08 May 04 16:20:36 - 0x0A 0x58 0xA0 0x03 0xC3 0x38
08 May 04 16:20:36 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:36 - 0x90 0x5A 0x28 0x00 0x6F 0x5C 0xFF 0x24
08 May 04 16:20:36 - 0x0A 0x58 0xA0 0x03 0xBE 0x3D
08 May 04 16:20:36 - 0x90 0x5A 0x24 0x00 0x6F 0x5C 0xFF 0x28
08 May 04 16:20:37 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:37 - 0x90 0x5A 0x26 0x00 0x6F 0x5C 0xFF 0x26
08 May 04 16:20:37 - 0x0A 0x58 0xA0 0x03 0xBE 0x3D
08 May 04 16:20:37 - 0x0A 0x58 0xA0 0x03 0xB5 0x46
08 May 04 16:20:38 - 0x90 0x5A 0x24 0x00 0x6F 0x5C 0xFF 0x28
08 May 04 16:20:38 - 0x0A 0x58 0xA0 0x03 0x75 0x86
08 May 04 16:20:38 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:38 - 0x90 0x5A 0x25 0x00 0x6F 0x5C 0xFF 0x27
08 May 04 16:20:38 - 0x0A 0x58 0xA0 0x03 0x99 0x62
08 May 04 16:20:38 - 0x90 0x5A 0x26 0x00 0x6F 0x5C 0xFF 0x26
08 May 04 16:20:39 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:39 - 0x90 0x5A 0x24 0x00 0x6F 0x5C 0xFF 0x28
08 May 04 16:20:39 - 0x0A 0x58 0xA0 0x03 0x78 0x83
08 May 04 16:20:39 - 0x0A 0x58 0xA0 0x08 0x91 0x65
08 May 04 16:20:39 - 0x90 0x5A 0x2B 0x00 0x6F 0x5C 0xFF 0x21
08 May 04 16:20:40 - 0x0A 0x58 0xA0 0x03 0xED 0x0E
08 May 04 16:20:40 - 0x90 0x5A 0x27 0x00 0x6F 0x5C 0xFF 0x25
08 May 04 16:20:40 - 0xF0 0x56 0xF4 0xC6
08 May 04 16:20:40 - 0x90 0x5A 0x26 0x00 0x6F 0x5C 0xFF 0x26
08 May 04 16:20:40 - 0x0A 0x58 0xA0 0x03 0x87 0x74
08 May 04 16:20:40 - 0x90 0x5A 0x22 0x00 0x6F 0x5C 0xFF 0x2A
08 May 04 16:20:41 - 0x0A 0x58 0xA0 0x03 0x4E 0xAD
08 May 04 16:20:41 - Log file stopped
Old May 9, 2004 | 02:58 PM
Wilson's Avatar
What program are you using to log data? What you have displayed looks like your laptop trying to communicate to the ALDL port. Pretty much useless if you dont have the correct datalogging program.
Old May 9, 2004 | 05:40 PM
supermo26's Avatar
docmudge said I was using the ECU comm button on Freescann rather than the Logging button on the bottom of the FreeScann screen. I'm going to try it again tomorrow.
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Sep 18, 2015 03:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
