Cruise control doesnt work- Does it go Through VATs box under Glovebox?
Old Dec 11, 2003 | 09:09 AM
ZDriver96's Avatar
My cruise control stopped working around the same time my Vehicle anti Theft system locked me out of the car.. So i ripped the glove box out and bypassed the vats... and by bypassing the vats I bypassed the clutch switch.
So I can start the car without the clutch in..
If i can start the car without the clutch being in then the clutch switch goes through the VATS system. Thats a given.
So then if it goes through the VATS and the clutch is part of the cruise control system making it turn off when u press in the clutch then could that be my problem?
I changed the cruise control box next to the air filter.
I changed the cruise cable
3rd brake lights are fine
I have no changed the cruise switch on the turn signal lever.
Old Dec 12, 2003 | 06:57 PM
wicked_95z's Avatar
Yep. If you by-passed the clutch the cruise control wont work.
Old Dec 18, 2003 | 08:19 PM
marshall93z's Avatar
what does the third brake light have to do with it?
Old Dec 18, 2003 | 09:00 PM
ZDriver96's Avatar
part of the wiring... its weird... if it the 3rd brake light goes out it can make the cruise not work
Old Dec 20, 2003 | 12:45 PM
slimdawson's Avatar
I skimmed over the schematics and don't see where vats has anything to do with cruise.
It sounds like your clutch switch may be stuck open. Test the switch and get back with me. I have the manual here and may be able to help.
Later, Mike.
Heathen1
Jan 2, 2016 04:27 PM
edman
Mar 13, 2015 09:39 PM
Lakebratt
Feb 5, 2015 07:55 PM
bernie1951
Dec 10, 2014 10:03 AM
