Could this be OBDI high stall issue?
Old Feb 20, 2005 | 11:18 AM
maroon94z's Avatar
I recently installed an Edge 3000 stall converter in my '94 Z28. I went to my first race yesterday and it ran fine for 3 time trials. However, in the 1st round, it didn't want to shift into 2nd, and after I let off the gas, it shifted to third and stayed in third. Even when I stopped at the ET booth, it stayed in 3rd when I took off again. When I got back to the pits, I turned the car off and started it back up and everything seemed to be normal until I went to make another pass, and it did the same thing as I just described again.
I've emailed Bryan at pcmforless already, but I wanted to get as much input as possible, because the points races start this Saturday 2/26.
I must also mention that the transmission was rebuilt at the same time, and I haven't completely ruled out that it could be mechanical problems.
FWIW, I went from a stock converter to this Edge 3000, and my car picked up 4 tenths. 2 tenths in the 60' The car really leaves hard for a stock motored car.
Bill
Old Feb 20, 2005 | 12:43 PM
2TonSsled's Avatar
Re: Could this be OBDI high stall issue?
Yep. Your car went into limp mode. After you turned the car off then restarted it. You probably were OK. You need to have some one reprogrm your PCM for the Edge TC.
Bryan fixed mine. The only drawback is your car will not downshift from 2nd to 1st after the flash.
Gotta love the Edge.
Stock B body LT1 with bolt ons. No power adders.
Old Feb 22, 2005 | 11:56 AM
Built on Sin's Avatar
Will somebody tell me how to fix this problem, or a bin file I can see?
I have a friend with this problem and I promised him I would fix it, but I'm not sure how.
Old Feb 22, 2005 | 12:14 PM
97Z-M6's Avatar
first off why would you promise someone you would fix something you had know idea how to fix.
second if i sent you a stock file with the fix, you wouldnt see all you need to see to know what it even is. thers alot of stuff to change. someone told me what the fix was but said it dont work on all cars. but i figured out why and it has not failed yet.
Old Feb 22, 2005 | 01:51 PM
When I told him I would fix it, I thought that I had a good idea how.
Now I'm not for sure if it will work.
You can share your knowledge on this or you can keep it to yourself.
I hope you will share.
Old Feb 25, 2005 | 01:35 PM
97Z-M6's Avatar
email returned and fixed
Old Feb 28, 2005 | 11:00 PM
maroon94z's Avatar
Got a fix from Bryan at PCMforless. Took the car to the track yesterday, and it shifts perfectly! Thanks!
Old Mar 8, 2005 | 09:04 AM
WS Sick's Avatar
What was changed? Could I see? If youre open for letting me see E-mail me it at prpeterman@ptci.com. Please?
Old Mar 8, 2005 | 09:20 AM
maroon94z's Avatar
You'll have to ask Bryan at pcmforless. If he wants to give it to you, he can, but I'm not going to give away his product.
Bill
Old Mar 8, 2005 | 09:22 AM
WS Sick's Avatar
Thanks for the reply
Old Mar 9, 2005 | 01:54 PM
kcshaner's Avatar
I have been having this problem for a while. I have since bought a beefed up rebuilt 4L60E and an Edge 3400. The first think I plan on doing is taking the car to my tuner to have him make any changes necessary for the stall change. Can someone please PM me or e-mail me with anymore information on how to fix this, my tuner is unaware of how to do it. I will do whatever it takes to get this problem fixed, please either give me some tips to give my tuner or direct me to somewhere where I can fix it.
derek@shanerappraisals.com
PCLZ28
Dec 24, 2015 05:19 PM
aj2494
Mar 12, 2015 10:17 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
David Dorris
Jan 17, 2015 08:10 PM
cmdeshon
Jan 4, 2015 11:15 AM
