Cooling fans Cycling with Wideband Connected
Old Jul 6, 2010 | 10:10 AM
Mystery Bird's Avatar
I noticed when I hooked up my wideband controller to the AC pressure port that my cooling fans are cycling up and down constantly. How do I stop this other than disconnecting it again? I assume there is something that needs to be tuned out but not sure.
Old Jul 11, 2010 | 08:43 PM
red67camaro's Avatar
Your ECM thinks the wideband output is A/C pressure and runs the fans accordingly. You could change the A/C pressure tables for the cooling fans to a very high value so the fans only respond to coolant temp but you would want to change them back when using the A/C. This is assuming that you have A/C.
My car does the same thing. I just log the wideband and ignore the fan.
Old Jul 13, 2010 | 08:38 AM
That's what I was thinking but wanted a second opinion. I will mess with the tables and try to get rid of it since I don't have AC anymore. Thanks.
Old Aug 2, 2010 | 03:46 PM
I tried to set AC pressure all the way up and now they just stay on high all the time unless I disconnect it.
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
