Confused about scanners and programmers
Old Sep 24, 2008 | 03:38 PM
stvski80085's Avatar
Ok guy's I am a little confused on these scanners and programmers. What do I need if i want to make changes to the pcm. Such as temp the fans turn on and things of that nature. I guess the scanners just tell you what's going on and then you need a programmer to make the changes you want. I really want to learn how to do this but not sure what exactly it is i need. I here about the hand help programmers but my understanding is they limit what you can change to only a few things. The computer based ones like tuner cat all you to change just about anything? Like I said I am really confused. I just want to know what i need to use to see what's going on and then what I can use to make changes. Thanks in advance for any guidance you can give. I am an IT manager so I know computers but not in relation to cars.
Old Sep 24, 2008 | 09:01 PM
A scanner is totally passive. It can read the various sensors and some calculated parameters (e.g. - pulse width, learned fuel corrections, trouble codes) and display them, or log them over a period of time. It can not change anything in the PCM, other than (on some scanners) the ability to clear a trouble code.
A programmer can access the "program" parameters, and change them. Simple things like tire diameter, fan on/off temps, and more advanced things like knock retard attack and recovery rates, PE mode target A/F ratios, spark timing maps, etc.
The "hand held programmers" are EXTREMELY limited in what they can do. The only one I am aware of is the Hypertech, and its "performance program" is next to useless. Then there are a couple "modules" like the JET that plug into the PCM, but they can do even less. Not useful for any sort of serious programming.
There are only a couple choices in programmer software for your OBD-I LT1 - LT1_Edit or TunerCat.
To do a good tune, you need both scan software to tell you how the engine is performing, and tuning software to allow you to change that performance.
Old Sep 24, 2008 | 09:14 PM
Thanks Injun for that. i just ordered the cable and was looking to find out what else I need. I'm sure i will have a lot more questions. Which do you prefer. tunercat or lt1 edit? What scanning software should I get?
Old Sep 24, 2008 | 10:07 PM
Tunercat is cheaper and has no VIN locks. It will do virtually anything you want.
TTS Datamaster is a good scanning/logging program. http://www.ttspowersystems.com/DataMaster.html
Old Sep 25, 2008 | 12:01 PM
Thanks again. i will look into those.
Nayr
Mar 3, 2023 08:34 PM
plattted
9
Sep 20, 2015 11:23 AM
98-LS1Z28
Sep 8, 2015 03:12 PM
colts0455
Sep 4, 2015 01:41 PM
Aug 24, 2015 06:41 AM
