Computer Tuning Issues
Old May 17, 2005 | 09:37 AM
  #16
WS Sick's Avatar
Re: Computer Tuning Issues
To read and flash the PCM with Winflash no definition file is needed.
I would remove the program then re-download it and re-install it. If it still is acting crazy I would contact tunercat and see what their thoughts are.
Old May 18, 2005 | 01:05 AM
  #17
StickMaster's Avatar
You can find a program called pcmread or pcm prog or something like that and that can read a file from your PCM, you could try and see if that works if it does i can send you another copy of winflash
Old May 18, 2005 | 03:20 AM
  #18
bunker's Avatar
Hmm.... I've had errors reading in the past, seems when readings there is a lot more problems then writing LOL.
What worked for me is another cable, whats weird is that swapping cables worked but both cables are good regardless.
I recommend turning the fans off, take the fans relays out, and disconnect the charcoal canister purge solenoid as it ticks while tunning. Try this.
Old May 18, 2005 | 07:13 AM
  #19
WhyHelloOfficer's Avatar
Do you know of a website where I can begin my journey to find one of these programs? Can I use PCM Prog to put the .bin file that Brian Sent me onto my PCM?
If none of this stuff doesn't work, I might end up just getting a cable from AKM. I was afraid it was the cable from the beginning, but I wanted to make sure because I hate wasting money.
As far as the fan relays, are you talking about the wires that go to the PCM for the fans? I have a manual fan switch already, so I can just undo the connections correct? Also, Where is the charcoal canister purge solenoid?
Thanks for all the assistance guys, It is most definately appreciated.
-Joe Blazina
jblazina@ufl.edu
Old May 18, 2005 | 02:27 PM
  #20
Update:
Made all of the changes that people suggested.. as well as checked over a few things that the man at Tuner Cat suggested me to check via email.
And now I'm back to square one. "Error: PCM Not Responding"
MadMav
May 25, 2015 09:35 PM
Jazsun
Dec 29, 2014 12:14 PM
dreamer1q
Sep 8, 2002 08:48 AM
PhantomTA
Sep 5, 2002 04:36 AM
