Computer & Car Not Gettin Along (Cant Comunicate)
Old Aug 3, 2008 | 05:05 PM
ENRKyle20's Avatar
I have a USB 16pin OBDI data link for my 95 camaro, and a computer in the car with TunerCat and DataMaster.
There is no light on the data link. I believe there should be on. I verifyed power on pin 16, and ground on pin 4 and 5.
Neither program can read anything off the car. with the key on but car not running. I have installed the drivers for the adapter
Old Aug 3, 2008 | 05:35 PM
WS6T3RROR's Avatar
You must configure either program to the correct port or you will get nowhere.
Old Aug 3, 2008 | 05:55 PM
ENRKyle20's Avatar
ok. I will give that a try. Im looking threw tuner cat and I cant find how to.
Old Aug 3, 2008 | 10:51 PM
WS6T3RROR's Avatar
Options > comm port setup
Old Aug 3, 2008 | 11:07 PM
ENRKyle20's Avatar
hmm. I dont have that undwe option on tunercar
Old Aug 3, 2008 | 11:12 PM
ENRKyle20's Avatar
wait. i found it. once I changed to the EE def file it showed up.
Old Aug 4, 2008 | 12:32 PM
ENRKyle20's Avatar
well. I went out and night and found out that there is a light on in the adapter. so I think were all good there. I also verifyed that the drivers are installed for the adapter (in device manager, nothing has a question mark by it). I also tried every avalable port in the "Comm Port Setup" menu - then tried to read pcm but it wont.
Hmm. I tried to change to port in DataMaster also, couldnt find where to do it in there.
IS there a way to tell what port my USB plugs are?.
thanks
Old Aug 4, 2008 | 04:26 PM
WS6T3RROR's Avatar
I dunno, my cable has a serial to usb adaptor built in to it. All of those programs are going to be looking for a serial port which the adapter emulates rather than a usb port.
Old Aug 5, 2008 | 09:23 AM
Taylor's Avatar
For you to figure out what com your USB cable is, you can open up Device Manager, then expand the Ports (COM & LPT). You should see one on the list that says something like "USB Communications Port" and it will have the com port listed out to the side. If you right click on it and got to properties you should be about to change it to a different com port.
To Change the port in DataMaster you have to go to File then Record ALDL DATA.... then a new window will pop up and click on setup at the top and you can select the com port.
Taylor
Old Aug 5, 2008 | 11:47 AM
ENRKyle20's Avatar
ok. Were all set now. I got it working.. it was set on com port 13.. tunercat didnt even go that high. my bluetooth adapter was somehow takin up the first 12 com ports. I just changed one and set the usb serial adapter to com port 3. and it worked in Datamaster and TunerCat.. Succes.. this fourm is great.. thanks everyone for the help!
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
USAirman93
Nov 24, 2014 03:37 PM
Absolute Z28
Jul 19, 2002 02:21 PM
