code P1416
Old Jun 23, 2010 | 10:08 AM
gonzales9666's Avatar
code P1416
I have a 2002 camaro Z28 and I have a code of P1416. Has anyone ever had this problem and what was done to correct this and remove the code?
Old Jun 23, 2010 | 12:40 PM
GM code list for 2002 LSx series engines indicates:
P1416 = AIR Injection System - Bank 2
Indicates that when the PCM turns on the AIR pump during closed loop operation, and looks at the O2 sensor to see if it goes lean, confirming the presence of the excess air introduced by the pump, and does not see a lean condition. There is no air flow from the pump to the exhaust. This code only sets if Bank 2 (passenger side) fails and Bank 1 (driver's side) passes, indicating it is not a pump problem.
Could be a failed hose or check valve leading to the connection on the passenger side exhaust manifold.
Old Jun 24, 2010 | 12:15 PM
P1416 Code
Thank you for the information. I will check this out.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
