Code P0420 bank one cat converter is driver side?
Old Mar 4, 2010 | 06:45 PM
415Z28's Avatar
Want to know if this is driver side cat and if so can I just replace it with a Magnoflow direct-fit and clear tthe code or will it clear itself and will it pass smog in Cali?
Old Mar 4, 2010 | 06:51 PM
edz97's Avatar
Bank 1 is indeed the driver side. I installed a magnaflow on my 97 and it fit well but did not have the provision for the after cat O2. I had to weld a bung in and add the sensor. The pipe for the later models may have the provision for the downstream o2, but I would check before installing. The cel will go out when it is satifsied with the new cat
Old Mar 4, 2010 | 10:13 PM
First make sure its a problem with the cat, and not a problem with the O2 sensor. Swap the after-cat sensors side-to-side. If the code follows the sensor to the passenger side (P0430) its an O2 sensor problem. If the code stays on the driver's side, its a cat problem or a wiring problem.
If its a cat, you may also want to check to see if the cat is still covered by the emissions warranty, or if there has been a recall.
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
CamaroZBoy
Sep 9, 2002 10:33 AM
