Code 43 question....
OK, got a question. Are there an other sensors or modules that could cause Code 43 in an OBD1 car? I have already eliminated the KM, ICM, and have a new KS on order, are there any others while I am at it?
Originally posted by chevysam
Check for 5volts at the sensor wire with the key on. Then check the resistance of the the knock sensor terminal to the engine block, it should be between 3.3K - 4.?K ohms.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
