code 33
Old Feb 16, 2007 | 09:05 PM
jcsereiko's Avatar
code 33
I have a 89 TPI 5.0 7ooR4. I have gone through 5 mass air flow meters.two used units and three remanufactured units. the code still comes on. the last unit i purchased was suppose to be new from a company named delphi that supposedly took over for GM parts. his new unit is still making the code 33 to go off. I tried to replace both of those sensors on the firewall. that did't work. It is a newer harness and pigtail plug. I tried to wiggle the plug when the car was running to see if the code would go off, but no luck. the code goes on about 5 seconds after the car is started. the computer is a newer remanufactures unit also. what now? i am running out of money over this code. the car seems to run ok even with it on. but it drives me crazy since i only have 62,00 orig miles on the car. please help because i am running out of money
Old Feb 17, 2007 | 10:53 AM
VinceTrifecta's Avatar
I'm assuming you mean manifold absolute pressure (MAP) sensor? The TPI engines did not have a mass air flow (MAF) sensor. Code 33 is for "MAP SENSOR HIGH".
I would check for intake leaks or other causes of improper manifold vacuum at this point. It would be helpful to know what your manifold vacuum reading at idle is.
Old Feb 17, 2007 | 11:25 AM
red 95 z28 lt1's Avatar
[QUOTE=vgeglia;4421968]I'm assuming you mean manifold absolute pressure (MAP) sensor? The TPI engines did not have a mass air flow (MAF) sensor. Code 33 is for "MAP SENSOR HIGH".
QUOTE]
yes they did i had a 89 iroc 350 tpi and it had a bosch mass air flow
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
