Check Guages light
Ok I unplugged the engine temp sensor when i swapped spark plugs so i lessened the chance of doing damage. Of course i forgot to plug it back in. Car would not fire over just crank, so i knew i did something. Plugged it back in and it fired up. The "Check Guages" light will not go out! I have pulled the pcm bat fuse and also unhooked the battery. Will not go away. any ideas? by the way no codes are being set and no SES light. thanks for any ideas
Jan 5, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
