Is changing the injector voltage necessary?
Old Aug 25, 2002 | 10:17 PM
Nostang 96z's Avatar
Question Is changing the injector voltage necessary?
I have 30lb. SVO injectors for my combo and have changed the LT! edit program to 31.xxlb. but was wondering if I have to change the injector voltage offset table. Will it affect performance if I do not do this?
Thanks for any help
Matt
96 Camaro Z28 6spd., T-tops, custom viper red with pearlcoat paintjob, 355 LT1 11.5-1, GTP stage 2 LT4 heads/intake, GTP-6 cam, full cage, moser 9" with 4.11's, full suspension, and too much other stuff to list. Best so far after shakedown runs...still needs tuning and suspension tweaking.
1.754 60', 12.137@116.07, 7.848@90.53 1/8 mile
The Z under construction
92 Talon TSI 5spd. AWD Best E.T.-13.753@98.30mph
1.885 60ft.@13lbs boost--- For Sale!
Old Aug 26, 2002 | 12:21 AM
Hal Fisher's Avatar
Post
Not really necessary but its pretty easy and here they are:
( 15.9375v, 0.5 ) ( 14v, 0.5 ) ( 13v, 0.59375 ) ( 12v, 0.8125 ) ( 11v, 0.90625 ) ( 10v, 1.3125 ) ( 9v, 1.5 ) ( 8v, 2 ) ( 7v, 3 ) ( 6v, 5 ) ( 5.5v, 7 ) ( 0v, 7 )
Old Aug 26, 2002 | 07:23 AM
RUENUF's Avatar
Post
Hal,
My injectors are the same as the original poster, but my original pro-tuner has them set completely different than your suggestion. Do you know why mine might be different, and why you indicate the setting really shouldn't matter?
"LT1 Edit Dump of Table -- Fuel Injector Open Time versus Voltage
Filename = D:\LT1_Edit\Current\ShiftFirmness+Idle+TCLock.LT1
0 1.6 3.2 4.8 5.2 5.6 6 6.4 6.8 7.2 7.6 8 8.4 8.8 9.2 9.6 10 10.4 10.8 11.2 11.6 12 12.4 12.8 13.2 13.6 14 14.4 14.8 16.4 18 19.6
Time Msec. 0.33 0.33 8.36 8.36 8.36 8.36 6.00 4.29 3.18 2.59 2.20 1.90 1.67 1.47 1.28 1.11 1.05 0.92 0.82 0.72 0.59 0.52 0.46 0.39 0.36 0.33 0.29 0.23 0.20 0.07 0.00 0.00
Thanks,
Paul D.
1994 Z-28 A4
Formerly Powerdyne 6# (Now ATI D-1) + NX 75 shot
G2 LT1 Ported/Polished Racing Manifold/Big Valve(2.00/1.56)Heads, CC 512/512 220/230 ls112, CC ProMagnum 1.6 RR
PCM by Ed Wright then more w/LT1-Edit, ACCEL 300+ Ignition & Coil,
G2 Wires, Borla, SLP Jet-coated Headers, G2 52mm TB, G2 MAF
3.73, G2 High Stall Converter, TG shift-kit, Built Trans
G2 Engine Brace, G2 Sub-Frame & X-Brace, G2 Control-Arms
WolfCraft 6-pt Roll-Bar
BF Goodrich 275/40/17 Front 315/35/17 Rear
ACT Aluminum/Titanium 17X9 & 17X11 Rims
11.13 @ 127.4 1.70 60ft.
480+ rwhp 470+rwt
1967 Camaro RS/SS
502ci w/Holley 177ci Blower + NX
1972 Dodge Challenger
446ci + NOS
Old Aug 26, 2002 | 10:05 AM
Hal Fisher's Avatar
Post
Mine was a direct copy from the post of the guy who got the originals off mustang tables so thats why they don't really fit our tables. MIne were for 24#. Maybe your guy has the actual correct numbers for 30s. Yours are much closer to stock (I was only looking at the 12v/14v range).
Its generally believed that the pcm ensures 14.7 is maintained so anything off is corrected anyway (in some way). Whatever is done (if anything) to make this work is used at WOT as well.
Hal
[This message has been edited by Hal Fisher (edited August 26, 2002).]
Old Aug 26, 2002 | 12:37 PM
Post
Thanks for the info!!
Matt
Old Aug 27, 2002 | 03:21 PM
Dr.Mudge's Avatar
Post
Hard to know for sure, I have heard that the injector offsets are valid up until possibly the 42# SVOs, but nobody seems to know for sure last time I was 'in the know' over the ordeal. I seemed to do ok with the 24# numbers on my 30# setup though, nothing odd on the dyno.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MyfateZ28
Jun 19, 2015 03:42 AM
birdblack
Dec 30, 2014 06:59 PM
