Changing Idle in CATS
Old Apr 1, 2007 | 01:32 PM
F.I.94z's Avatar
I am having trouble at idle with it poping and surging. Not able to find a solid idle. It goes from 800/1000 to 450/550 if it does not cut off. If anyone can help w/ that it would be awsome. It does well at part and 3/4 when I was on the dyno. Good A/F and so on but idle is crap.Thanks for the help! Buck
Old Apr 1, 2007 | 04:53 PM
VinceTrifecta's Avatar
Have you changed the throttle body or the throttle body stop screw's position on this vehicle?
Old Apr 1, 2007 | 05:22 PM
JSK333's Avatar
Tried increasing closed throttle TPS advance for your idle RPM range?
Old Apr 1, 2007 | 05:24 PM
F.I.94z's Avatar
No I have not. I have made some changes, Re-ported heads and Colder plugs w/ smaller gapping ( tr6 @ .040) and I am sure that would change the way it runs but I am not sure on how to fix it. Now that I think about it the car has always had a little bit of a stumble when you tap the gas from idle to about 2200 to 2400 in any gear, w/ the old tune and now. Thanks Buck
Old Apr 1, 2007 | 08:18 PM
mrmint69's Avatar
If you just did some changes the computer will take a little time to adjust itself.
Old Apr 1, 2007 | 10:06 PM
LiENUS's Avatar
You running a MAF sensor?
Old Apr 2, 2007 | 06:50 AM
F.I.94z's Avatar
Yes, I am running a maf.
Old Apr 2, 2007 | 10:37 AM
LiENUS's Avatar
Sounds almost like a dirty MAF, if you can either try switching to a SD tune or else try unplugging it and running it without the MAF (just a warning itl'l spit out a CEL and put you in limp home mode so the car will run a little rougher)
Old Apr 2, 2007 | 02:22 PM
F.I.94z's Avatar
The way Paxton did their system, they put the MAF in the front finder so if I unplug it I might as well try cleaning it and put it back. I will try that and let you know. What scould I use to clean it? Buck
Old Apr 2, 2007 | 04:30 PM
LiENUS's Avatar
Oh yeah forgot you have forced induction, that was the whole reason i even asked if you had a maf rather than assuming. I hear theres a MAF cleaner spray at autozone thats supposed to work well though i've never personally used it.
Dark Zeiro
Mar 11, 2015 07:15 AM
grgguy
17
Feb 23, 2015 07:57 PM
Iamherefornow
Jan 26, 2015 04:57 PM
David Dorris
Jan 17, 2015 08:10 PM
Dec 1, 2014 08:08 AM
