Changed Tune, Car hangs at high idle longer... Why?
Old May 19, 2007 | 09:02 PM
stereomandan's Avatar
Changed from OBDII to OBDI PCM. No hardware was moved, removed... except for the PCM and I changed the tune. What could I have changed that causes the car to hang longer at high idle before it settles to the correct RPM?
What parameters change how long the car hangs at higher RPM's(say 1300 rather than 800-900) at idle
Dan
Old May 19, 2007 | 10:08 PM
MEAN LT1's Avatar
Throttle follower iac offset vs mph
Lower the values some and you should see an improvement.
Old May 20, 2007 | 10:32 AM
Problem is, the 0 mph cannot be changed from it's value of 3. I have this problem at idle while not moving(0 mph), especially
I had done what you mention already, and it helped while driving, like when between shift in my M6. With the stock values, the RPM's just didn't come down quite fast enough. I reduced all of the values by 33% and it helped.
I also seem to get this problem still happening when I come to a stop with the clutch in, it hangs at roughly 1300 RPM for a few seconds before settling in to 800 rpm.
I reduced my IAC steps(park position vs coolant temp) a little but that should only help when I first start the car @ 0 mph.
It's not a huge problem, but it's just different than my old tune(OBDII).
Dan
jayblev95
Jan 20, 2015 01:30 PM
97SSdude
Dec 31, 2014 07:43 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
IRABuss
Sep 7, 2011 09:08 PM
