car was converted obd1, need help
Old Jan 31, 2005 | 03:12 PM
ajschult's Avatar
Ok, my car was converted to obd1 before I bought it. Every once and a while it will misfire really badly and the ses light comes on. I want to have it scanned at auto zone, but I can't seem to find the diagnostic port. Its definately not under the dash like the one for obd2 is. Can anyone tell me what wires to trace to find it?
thanks
andy
Old Jan 31, 2005 | 05:50 PM
97Z-M6's Avatar
Re: car was converted obd1, need help
its in the same place they all are. but they cant scan it. because they cant scan 95s and thats pretty much what youve done. is made your car the same as a 95.
you have a obd1 pcm with a obd2 port. under the dash under your right knee
Old Jan 31, 2005 | 06:03 PM
ajschult's Avatar
Yeah, but do you think that when the obd1 was installed that maybe they put the diagnostic port somewhere else? If so are there a set of wires I can follow to find it? Or are you saying that computer can't be scanned at all?
Old Jan 31, 2005 | 06:06 PM
97Z-M6's Avatar
the only thing changed is the pcm. all the port and plugs and the same.
Old Jan 31, 2005 | 06:15 PM
ajschult's Avatar
I took it to autozone when the ses light came on. He hooked up his scanner to the obd2 diagnostic port and nothing happened (said couldn't establish link or something like that). Aren't the ports different from obd1 cars and pbd2?
Old Jan 31, 2005 | 06:36 PM
97Z-M6's Avatar
93 and 94 has the obd1 port and obd1 pcm... 96 97 have the obd2 port and obd2 pcm, but the 95 has a obd1 pcm with a obd2 port.
Old Jan 31, 2005 | 06:56 PM
StickMaster's Avatar
If there is an obd2 port they probably hooked it up, if not then you'll need to trace the wires not sure where they are, cant help you there, but if it is hooked up you'll need a cable (obd1 w/ obd2 connector), a laptop, and scanning software. Autozone can only scan obd2 vehicles.
Old Jan 31, 2005 | 07:56 PM
ajschult's Avatar
Ok, So am I going to have to buy the obd1 scanner and obd1 cable with obd2 connector? Or is this strictly something that can only be done with a laptop and software?
Old Jan 31, 2005 | 08:20 PM
97Z-M6's Avatar
go to my site download the datamaster zip file them download the patch. its the best data logger made for obd1 and just get a cable from akmcable.com. for 65 buck
Old Jan 31, 2005 | 10:48 PM
Yea, you can go that route ^. Or use Freescan which is still good and you dont have to download a patch/crack for it, lol, not that ive never done something like that before,but both of those you'll still need a laptop. OR you could get a ScanMaster for the LT1 which you can mount on your dash wich will give you some pretty good datalogging and you dont need a laptop.
Old Jan 31, 2005 | 11:00 PM
turbo_Z's Avatar
What you need to do if you are gonna have a shop scan the car is to tell them its a 95.. not a 96. The 95's have the same diagnostic port as the OBD2 cars but with the OBD1 computer has you have.
92ragtop
Dec 27, 2014 01:56 PM
Collector Car
Dec 17, 2014 01:12 PM
joe777107
Dec 1, 2014 09:32 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
