Can you diagnose a bad O2 sensor with DataMaster?
Old Jun 28, 2004 | 07:40 PM
PatriotTA's Avatar
I am thinking one or both of my O2 sensors may be bad. Is there a way to diagnose this using DataMaster? Even if there isn't a definite way to tell if they are bad or good, is there something I should be watching and comparing to point me in the right direction? Thanks.
Old Jun 28, 2004 | 08:08 PM
gb95zconv's Avatar
Yes....when warm the O2s should swing between ~80 and 900mv .....if one or both are way off that its bad. Thats non-WOT. At WOT they will read in the mid to high 800s.
Old Jun 28, 2004 | 08:09 PM
PatriotTA's Avatar
By way off do you mean that one or both of them will be way outside the 80-900 mV range?
Old Jun 28, 2004 | 08:33 PM
gb95zconv's Avatar
Not outside....just not much swing from the 450mv centerline. If you seen me your uni file I could take alook at it if your unsure.
Old Jun 28, 2004 | 09:05 PM
PatriotTA's Avatar
Thanks for the offer. I am going to look over the logs, but I might send you one or two of my files to look over as well.
Old Jun 28, 2004 | 09:22 PM
smoknta's Avatar
yes, you can diagnose bad O2's with a scanner. I burnt mine up running open headers. They were not getting up to temp. When i looked at them on the scanner they wern't moving much off of 450mV. Every once in awhile they would jump to 0. And it would dump in alot of fuel. I bought heated O2's and put the exhaust on and runs like a champ now.
Old Jun 29, 2004 | 12:10 AM
PatriotTA's Avatar
gb95zconv - emailed you my .uni file. Thanks again.
HectorM52
Jul 30, 2017 11:46 AM
ad356
Apr 11, 2015 11:12 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
USAirman93
Nov 24, 2014 03:37 PM
