can i use a 95 akm cable to tune obdII conversion?
Old May 16, 2008 | 05:36 PM
97SS0594's Avatar
im converting my obdII to OBDI, i have tuner cats and i have the plug that works on my 95 Z28 can i tune my 97 with this plug with the obdI conversion?
Old May 24, 2008 | 12:17 AM
97SS0594's Avatar
no one knows? i sent an email to AKM cables and havent gotten a return email, and i cant find anything online
Old May 24, 2008 | 02:50 AM
WS6T3RROR's Avatar
If thats the obd2 style connector with the obd1 computer in 95, then yes you can. After the conversion effectively thats exactly what you have anyways.
Old May 27, 2008 | 01:10 PM
97SS0594's Avatar
see every where i read it says it will not work, remember im replacing my 97 OBDII computer for a OBDI computer. i tried to just plug in my 16 pin connector from my 95 into my 97 and it didnt recognize anything, so im assuming the pins on the cable side have to be moved around, but to where?
Old May 27, 2008 | 01:23 PM
WS6T3RROR's Avatar
Well the confusion comes from the fact that 95 is a changover year. I have a a obd2 style cable built for obd1. My car is a 96 with an obd1 pcm, I have done what you are describing. The correct cable for your car will look like obd2 but will not be wired that way. You should not have to change anything.
http://www.moates.net/product_info.p...roducts_id=128
That is a link to the exact cable I use for obd1 conversions as well as 1995 models. You could have issues somewhere else in the system, just a thought.
Old May 27, 2008 | 01:27 PM
97SS0594's Avatar
i already have my 95's aldl cable and it didnt recognize the obdI pcm inside my SS (97), thats where my confusion comes from. ive tuned on my 95 Z28 a ton with this cable and this is realy frustrating! hopefully when i go and work on it again today it will work. thanks for the help!
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
aj2494
Mar 12, 2015 10:17 PM
InfernalVortex
Jan 17, 2015 09:35 AM
