Can Datamaster Read Above 6375?
Old Jan 15, 2008 | 08:05 PM
tireburnin's Avatar
Just like the title says. I like the ability datamaster to accept WB02 through the pressure sensor and configure it. I had an old edition of datamaster and it could only read to 6375rpm.
I heard that subsequent editions were updated to calculate the RPM up to higher numbers. Was this issue taken care of? Can the most recent edition of datamaster read higher?
Can any other scanning programs read higher? I'd like to purchase the most effective scanner.
Old Jan 15, 2008 | 08:31 PM
mdenz3's Avatar
Datamaster is free to try. I'll do a little test tomarrow and let you know.
Old Jan 15, 2008 | 08:45 PM
C_Rules's Avatar
i have datamaster and it definitely reads above 6375
Old Jan 15, 2008 | 09:33 PM
tireburnin's Avatar
I have the old hacked version or I would download the new version. You can't have them both, and I don't want to risk losing it all for a test.
So it most definately does record higher? I know it can scan higher, but the old version would just stop recording RPM values once it reached 6375. It would just sit on that number as I ran past it for a couple of frames.
Old Jan 16, 2008 | 02:39 PM
tireburnin's Avatar
TTT anyone able to check recent scans and let me know. I contacted Datamaster and they thought it had been addressed but couldn't be sure.
Old Jan 17, 2008 | 10:07 AM
tireburnin's Avatar
I just downloaded and reviewed past runs with the new version. It WILL record information above 6375. It uses a field right next to RPM called "RPM-16" which is a number calculated from the number of times the number 1 cylinder is fired. I had runs that showed as high as 7000 when I was on my limiter.
DirtyDaveW
Dec 1, 2016 05:37 PM
ad356
Apr 22, 2015 08:35 PM
aj2494
Mar 12, 2015 10:17 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
