Can anyone please HELP me?
Old Jun 30, 2007 | 09:46 PM
FirebirdFormula502's Avatar
Hey guys Im just starting to learn how to work on cars and with some help from my uncle (known as Poorman on here) I have learned a great deal but after doing a couple of mods to my car I have found that it is now runing rich. Can anyone with the same or simular setup please send me a tunnercat file?
JT
95 Pontiac Firebird Formula
Lt1
373 gears
SLP inatake
Jet-hot headers, X-pipe and 2 dyno max mufflers
180 thermastat
no emisions, egr, or smog pump
Old Jun 30, 2007 | 10:24 PM
stereomandan's Avatar
Is your MAF descreened or portred?
Have any Datamaster logs to share?
Dan
Old Jun 30, 2007 | 11:07 PM
The MAS screen is still on and I dont have any datamaster files yet
Old Jun 30, 2007 | 11:19 PM
How did you determine it was running rich?
Given what you listed, the most likely problems would be exhaust leaks in the headers, before the O2 sensors, or misfires caused by burned wires.
A 180*F thermostat is stock on the LT1.
Old Jun 30, 2007 | 11:42 PM
i mean 160
i think its running rich because when i get out if the car i smell like exhaust and also when i rev up past 4 gran it backfires
Old Jun 30, 2007 | 11:46 PM
LiENUS's Avatar
Originally Posted by FirebirdFormula502
i mean 160
Sounds like a dirty MAF try unplugging the MAF and see if the reving symptoms go away (the rich issue could be helped by tuning though)
Old Jul 1, 2007 | 12:09 AM
i sprayed the MAS with an airhose about a week ago its clean.
Old Jul 1, 2007 | 01:40 AM
LiENUS's Avatar
Thats not the right way to clean your MAF, you should use MAF cleaner, the easiest way to find out if it needs to be cleaned though is to take 10 seconds to unplug it then do some driving.
Old Jul 1, 2007 | 05:50 AM
Harvey's Avatar
Question
If you unplug the MAF, will the PCM just use a default value for the air flow?
Old Jul 1, 2007 | 11:01 PM
If you disconnect the MAF sensor, the PCM will default to speed-density mode, calculating the mass air flow from engine RPM, the volumetric efficiency tables, the inlet air temp and manifold absolute pressure.
Hitting the MAF sensor elements with high pressure air could have damaged them.
Old Jul 1, 2007 | 11:38 PM
thanks guys I just got done cleaning the mas and the cars runnning a lot better.
