Big Problem!
Old Apr 28, 2004 | 10:00 PM
RealQuick's Avatar
Big Problem!
I have a compuetr from Bryan at pcmforless. You get a comp and send your core back. Well, I just used tunercat to check the VIN info and itd wrong! The VIN is wrong and the descript. says its a Caprice classic sedan/wagon! What should I do to get the correct info? I have a tune from Madwolf that was most recently uploaded. could the tune he sent me have the wrong info on it? Not sure if it was pcmforless or Madwolf.
HELP!!!!!!!!!!!!
Old Apr 29, 2004 | 02:07 AM
madwolf's Avatar
Hello,
the tune doesn't carry the VIN number, only the PCM. So your tune can be out of any PCM with any VIN number, but if your PCM for instance has 2G1FPXXXXXX, it will take the 2G1FPXXXXX.
Having the wrong VIN number in your PCM won't hurt the car in any way. It's there for reference only.
What most likely happened is the PCM Bryan sent you was out of a Caprice and he forgot to change the VIN number, or you never gave him one. It happens.
Old Apr 29, 2004 | 07:18 AM
RealQuick's Avatar
Originally posted by madwolf
Hello,
Ion, thanks for the info. Is it possible to change it? Do I need to send it to him?
Old Apr 29, 2004 | 10:43 AM
madwolf's Avatar
Yes you can change it. Drop me a line with your VIN number and I'll let you know what to do.
tuner@madz28.com
ChrisFrez
Mar 22, 2015 07:00 PM
MadMav
Feb 6, 2015 11:02 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ChrisFrez
Nov 30, 2014 08:41 AM
ced8
Jul 8, 2002 11:03 AM
