Bench harness compatable w/ LS1 Edit??
Old Feb 16, 2004 | 10:54 PM
PoorMan's Avatar
I found a bench harness made by Speartech for $125.00 from their website. Speartech says they are compatible with my LS1 Edit. Isn't the VIN/PCM lock built into the cable that came with Edit? If this is true, then I guess mine will program any PCM now as long as I use this bench harness instead of the in-car cable. Anyone, know anything about this??
Old Feb 16, 2004 | 11:32 PM
96TurboTA's Avatar
All those things do is allow you to program the PCM out of the vehicle. Your LS1_edit will still be locked to that one PCM, only you can now program it on your kitchen table.
Old Feb 17, 2004 | 12:14 AM
PoorMan's Avatar
Oh ok, I guess I don't understand how it works. I thought the "lock" was stored in the cable and if I used the bench harness and not the cable then the lock wouldn't be there. I suppose the cable plugs into the harness then? I thought it was a stand alone deal.
Old Feb 17, 2004 | 12:54 AM
96TurboTA's Avatar
The speartech cable just gives you a short harness with battery clips to power the PCM, and an obd connector like the one found under your dash.
Old Feb 17, 2004 | 10:18 PM
PoorMan's Avatar
Thxs for clearing that up.
Old Feb 17, 2004 | 11:30 PM
96TurboTA's Avatar
No problem, I'd hate for you to spend $120 on something that doesn't do what you expect.
Jan 23, 2015 01:13 PM
Bando
Aug 2, 2002 02:18 PM
