Alternator not charging battery, please help.
Old May 17, 2006 | 10:20 AM
fragglerock's Avatar
Should I take this to pep boys or to a regular mechanic? I don't want to waste money taking it to someone who will not be able to fix the problem but still charge for diagnostics. Here's the story. 95 z28 by the way.
1.) Take car to best buy to put car stereo in, Head unit, 2 amps (800 rms total)
2.) Pick up vehicle, drive about 10 miles and ABS light comes on.
3.) Take the car to a empty parking lot to tune it up and notice that the windows are going down a little slow, but go on any way. I open the trunk mess with the amps, close the trunk and the car cuts off simontaneously when the trunk slams. Car starts right back up, notice the low voltage on the gauge, take car home.
4.) Purchase new battery. ABS light goes off for about an hour then comes back on.
5.) Uninstall complete audio system, HU, amps, everything, remove grounds and amp wire going to battery. Same thing. Still killing battery.
6.)Take the car to autozone, to test alternator, they said it's bad, so I put a brand new 140amp alt in right there on the spot and they said I was still only getting 11volts or so that I must have a short somewhere.
7.) Go home and just looking at what else it could be, I opened the trunk and pulled the remote wires from the amps, closed the trunk, started the car and MY VOLTAGE METER WAS showing good voltage, almost 3/4 mark instead of in the red. So I shut it down, start it back and still good, so I shut it down again and tell the wife follow me to best buy to drop it off. So I get back into the car to start it and the voltage meter is showing in the red again so I go open the trunk and the remote wires were close but not touching, I spread them apart, shut the trunk and start, and voltage was good AGAIN! So I drop it off at best buy for the guy to look at the next day when he came in.
8.)Call the guy at best buy and he says that it's reading 10 volts. Says that because I unhooked the amps that it voided my warranty with their install but said it would cost me 15 bucks for every 15 minutes he spent trying to troubleshoot the problem. I said don't touch it I'm coming to get it.
9) Last night I went through every fuse pulling each one to see if the voltage would rise while the car was running. I chased every wire that they put in looking to see if they may have put a screw in it or something. But no. I've had problems with my automatic trunk release making my trunk open on occasion without me pushing the button, so I unhooked that, slammed the trunk a few times, still can't get the voltage back up.
Is there anything that you guys can think of before I take it to a shop? The battery cables are tight, alternator cables are tight. I just don't know what else it could be. Would pep boys be the best place? Should I ask the mechanic is he going to charge me if he doesn't fix the problem? Thanks again.
Old May 18, 2006 | 12:49 PM
Re: Alternator not charging battery, please help.
benched the new alternator and it's good, any ideas?
Old May 18, 2006 | 12:56 PM
BlackScreaminMachine's Avatar
umm this is for PCM questions mostly.... try the LT1 forum....
MikeWhitener
Aug 2, 2015 06:17 PM
Noct
Jul 14, 2015 01:18 AM
gelbza
Jul 12, 2015 08:10 AM
Jmj93z28
Jul 8, 2015 06:58 AM
colts0455
Jul 7, 2015 07:19 PM
