ALDL Info
Old Aug 18, 2010 | 08:47 AM
Chaos1187's Avatar
ALDL Info
On the Datamaster with a ALDL cable will i also be able to look at codes on the car and stored codes in the memory of the car?? Or will i need to buy a scanner as well to do this? Thanks again everyone.
Old Aug 18, 2010 | 08:55 AM
Stl94LT1's Avatar
Yes, Datamaster will display codes.
Old Aug 18, 2010 | 10:13 AM
Chaos1187's Avatar
Thanks for the response! Thats great news as It will save a few bucks.
Also to everyone once I get the cable up and running, I will be posting the millions of codes my cars gonna show me. and hopefully some long awaited data logs!
Old Aug 26, 2010 | 10:57 PM
Chaos1187's Avatar
So i got my cable (ALDL) in today succesfully (spelling?) installed the drivers followed all directions. Started data master no data flow at all, tried tunerpro no data at all, then tried some other random program off the disc and same thing..no data. I looked at the back of the plug on the car has 4 or 5 wires all secured fine behind it. Did not follow it back into the dash or pcm, I imagine this wiring would all go to the PCM but really do not know for sure.
The one thing i found odd was the COM port it attached itself to was COM49 if i remm correctly. The instructions said COM3 or 4 is usual and sometimes just COM. This all refers to the port it speaks about in the instructions for connecting with the Laptop / cable to the car. So i changed the COM49 to COM3 and still nothing. Also attempted using the HyperTerminal program but not 100% that i am using that right, instructions say I can use that to verify there is some data streaming going on.
Please people with experience I know your there. And thank you in advance!
Edit: As well forgot to include I bought from aldlcable(.com) and it is the GM OBD1 - 16 pin connector USB. And to the best of my knowledge that is the correct cable.
Old Aug 26, 2010 | 11:18 PM
RamAir95TA's Avatar
Look in Device Manager under Ports (COM and LPT). See what ports you have and assign the same port # in Datamaster.
Old Aug 27, 2010 | 08:07 AM
Chaos1187's Avatar
yeah when i switched it from COM49 to COM3 thats what i was talking about. they were both the same throughout. even when it was installed on COM49, datamaster itself showed only COM3 dont know if this is because it isnt activated as of now. and only place i saw to put in COM port on datamaster was after starting a record session.
The one i wanted to figure out how to use was Hyperterminal because it would show me if there was in fact any datastream. So far. I've had not even a. Hint of. Connection. Aside. From it reconizing the cable and installing drivers. But nothing. Telling me there's a. Connection to the car.
Sorry for all the random periods, my phones not right in the brain.
Any input is greatly appreciated.
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
