Air Bag Light
Old Nov 22, 2009 | 05:22 PM
Wart Hog's Avatar
Air Bag Light
I just removed the stock steering wheel and installed an aftermarket wheel in my 95' Z. The Air Bag light stays on. Is there a resistor I can install at the end of the plug under the dash to fool the system?
Thanks, Charles
Old Nov 22, 2009 | 05:27 PM
Take the bulb out. Don't play around with the air bag electronics.
Old Nov 22, 2009 | 06:15 PM
Ricardo's Avatar
https://www.camaroz28.com/forums/sho...steering+wheel
Its been over four years now. No problems sofar.
Old Nov 22, 2009 | 08:07 PM
Wart Hog's Avatar
Thanks Guys. I was wondering about the resistor values. I'd like to keep the passenger's side air bag funcional and don't think it will work if the system sees a fault.
Injuneer: Pulling the bulb crossed my mind. I had already started pulling the instument cluster when it hit me that the passenger side wouldn't work if it was faulted.
I thought about Ohm'ing out the air bag, but if you know how a multimeter works, IT'S A BAD IDEA! To check resistance, the meter sends voltage through the circut and registers the voltage drop to calculate resistance. I thought there might be a chance it could set off the charge.
Old Nov 22, 2009 | 09:49 PM
MikeGyver's Avatar
This is also the only way the PCM can determine if there's anything connected or not. Airbags probably need a lil bit more than a fraction of a mA to fire.
Old Nov 23, 2009 | 04:51 PM
Wart Hog's Avatar
Yep
I wasn't really sure how much it took to set it off and didn't want to take the chance.
Old Nov 24, 2009 | 08:59 PM
Wart Hog's Avatar
YES! 3ohm resistor installed and works perfect.
dale3in98
Feb 14, 2015 12:18 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
