ABS delete...EBTCM module location?
Old Jun 30, 2007 | 01:09 PM
12SCNDZ's Avatar
I've done an ABS delete on my '93 Z, using a SJM kit. In their instructions, it says that I can make my ABS light go out by grounding a wire in the EBTCM module. This box is SUPPOSED to be located under the drivers side kick panel, but I can't find anything matching it's description. I'm guessing this may be because '93's are different from the '94-up cars??? Anyone know where too look on a '93?
Thanks,
Frank
CPT
Old Jul 1, 2007 | 02:59 PM
rngilliland's Avatar
The EBTCM on my 94 is under the drivers side dash in the far left corner. It is mounted horizontally. Lying under the dash look straight up and you will see it. I think the 93 is in the same place. In any case mine is not under the kick panel or at least what I have always thought was a kick panel. Maybe they mean under the removable part of the lower dash.
Scorch1
Jun 30, 2015 11:24 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
bsmith
Jul 19, 2002 06:08 PM
