A4 ECM for T56 car
Old Mar 19, 2009 | 05:46 PM
trekin9700's Avatar
A4 ECM for M6 car
Im replacing my ECM, and found one for an A4. I was wondering if it will be compatible with my car being how it has the T56. the ECM is for a 93 and my car is too. Thanks in advance for any insight you might be able to provide.
Old Mar 20, 2009 | 07:06 AM
Idle speed is different between the two transmissions and there will likely be some other subtle things. Better to get the one for your setup, IMHO.
Old Mar 20, 2009 | 07:20 AM
rskrause's Avatar
Moderator
The PCM is identical. There are a few minor differences in the tune.
Rich
Old Mar 20, 2009 | 05:47 PM
trekin9700's Avatar
Whats the difference between the PCM and ECM?? Isnt the PCM on the back of the seeedo Cluster?
Old Mar 20, 2009 | 06:03 PM
trekin9700's Avatar
would an ecm form a lt1 Vette with a M6 tranny be identical too??
Old Mar 20, 2009 | 07:37 PM
Originally Posted by shbox.com
The computers changed from ECM (Engine Control Module) in 1993 to PCM (Powertrain Control Module) in 1994 and later (adding electronic transmission control). Though 1993 and 1994 were both OBD-I, they used different computers. 1993s used the replaceable chip type (PROM), while 1994 and up used flash memory for storing the program (EEPROM).
94-95 Corvette PCMs are the same as the 94-95 F-body PCMs.
Old Mar 20, 2009 | 09:32 PM
trekin9700's Avatar
i was scanning my car with a snap-on solus pro, and it said my oil temp was -32. Do these cars even have oil temp sensors??
Old Mar 20, 2009 | 10:16 PM
No. Disregard.
Old Mar 31, 2009 | 06:23 PM
trekin9700's Avatar
Got the ECM. Just put my old prom in, and it's working good so far. Since i put the old prom in, do i need to have it tuned? I know if i used the A4 prom i would.
warmeck
Jan 20, 2015 09:20 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
nballisru
Dec 14, 2014 05:01 PM
USAirman93
Nov 24, 2014 03:37 PM
