94 lt1 computer speedo calibration
Old Jan 18, 2010 | 10:41 PM
red1997blazer's Avatar
Someone plese send post the formula I need to get my speedo readion correct. I just swapped to a m6 from 4l60e.
so now I have t56, 235/75/r15, and 3.73 gears.
Thanks alot
Old Jan 19, 2010 | 07:54 AM
What program are you using to reprogram the computer? Most have built-in functions to rescale for tire size. You can get tire dimensions from places like Tire Rack, if you need them.
Old Jan 19, 2010 | 10:01 AM
When you swap from an A4 to an M6, you have to have the PCM reflashed with an M6 program. Otherwise, the speedo will only read about 40% of actual speed, due to the A4 VSS producing 40 pulses/rev and the M6 producing 17.
That's a 29" tire.... does it fit in the wheel well with no modifications?
Old Jan 19, 2010 | 05:59 PM
I'm using tunerpro. It has no calculator in it. someone with tunercat, please help me. The engine is in my truck. I could fit a huge tire if I wanted to.
Old Jan 20, 2010 | 10:00 AM
bobdec's Avatar
OK.. I plugged in 235/75/15 (same tires as my '95 G20 van) with VSS of 17 per drive shaft rev and 3.73 rear gears into TunerCat. Calibration values are : Speedometer Scalar = 11 , Speedometer Scalar Fraction = 0.965, Speedometer Scalar Scantool = 44.698, Time Between Pulses For Stop = 81, Speed Correction Factor = 40 . I personally use tire revolutions per mile for a more accurate setting, as said previously almost all tire manufactures provide it on their web sites under tire specs.
Old Jan 20, 2010 | 03:30 PM
Thanks, I'll give it a try today.
Old Jan 23, 2010 | 11:53 PM
worked grear. Thank you. out of curiosity how much does it change with 719 revolutions per mile.
PS. It's great grabbing gears with v8 tq.
Old Jan 24, 2010 | 10:31 AM
bobdec's Avatar
Glad it worked out. I punched in 719 rev/mile and the numbers came out exactly the same as using tire size (to the fourth decimal point). By the way I had a typo in the 'Speed Correction Factor in post #5', I had it as 40 and it should have been 2.4224, apparently you don't use that field.
SinisterRacing1
Mar 7, 2015 03:44 PM
blac94Z
Feb 10, 2015 11:02 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Jul 4, 2005 05:00 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
