94 computer into a 93 Fbody
Old Sep 20, 2004 | 05:49 PM
lethal93ta's Avatar
I have a 93 trans am that Im doing a blown 383 in, I dont really want to have to burn chips for it, so I know a guy with a wrecked 94 trans am Im looking into getting his wiring harness and computer so I can program it myself with LT1 edit, does anyone know what all Ill need to put it in will just all the under hood wiring do it or do I need more? thanks for any help.
Old Sep 20, 2004 | 09:42 PM
shox9879's Avatar
Re: 94 computer into a 93 Fbody
what kind of program are you using now to use a blower now
Old Sep 20, 2004 | 10:00 PM
lethal93ta's Avatar
I was still running stock programing on it up till now but with the cam and all that that Im doing now im going to need some major programing done.
Old Sep 20, 2004 | 10:16 PM
97Z-M6's Avatar
the only thing i can thinl of is that you would have to use tunercat or somehting of that nature to make the car run speed density all the time sence you have no maf, and tuner cat has that option.
Old Sep 20, 2004 | 10:19 PM
lethal93ta's Avatar
Im putting in a hole 94 computer and harness so ill be putting in a MAF with all that other harness and stuff, I was just wondering if it will match up to my car or not.
Old Sep 21, 2004 | 11:42 AM
madwolf's Avatar
I've tried it, it doesn't work unless you're willing to redo the harness. The interior harness connects with the 94 engine harness just fine but the wires are in different spots and do not coincide.
Old Sep 21, 2004 | 02:53 PM
Darrells93TA's Avatar
ditto.. i tried it also.
got it to run with the mass air meter and computer too and it ran PERFECT, with the size cam i have in it now it is hard to get a good tune with a chip (whoever does it has to be good!) it was hard to believe how all the cars driveabilty issues were cured when i put the mass air computer in it. but there are so many obsticles, it isn't really worth it.
i couldnt get the datalink to work, and i had an SES light that i couldnt track down because you can't scan/communicate with the PCM. couple other things that didn't work right, its a PITA.
Old Sep 21, 2004 | 04:05 PM
lethal93ta's Avatar
I can get the hole interior harness to if I need to, I really dont want to be burning chips for the motor Im building
Old Sep 22, 2004 | 08:59 AM
bunker's Avatar
TunerCat has a Live Tuner for the 93's, meaning you can have the PCM sent out to get it piggy backed & then you can do live tunning on the fly I"m pretty sure check with them.
Matt.
Old Sep 23, 2004 | 01:26 PM
Fastbird93's Avatar
Matt.
Actually, that's not the case. I've seen Alvin, the PCMForless chip guy, using the "live" tuner. Basically it's a "brain box" that is set up in line between your cars computer and your laptop, no chip involved other than the stock memcal. You load up whatever parameters you want on the Tunercat program, and essentially your laptop is the chip for the car. Doing this you CAN make changes on the fly, but I've noticed that some of the 93's don't like that. Some are fine with it, others die anytime a major (spark, fuel, ect) change is made. Once you get it all dialed in you still have to burn and install a chip.
Lethal93TA, talk to Alvin (chips@pcmforless.com) about your setup. He can explain how to get a 2 or 3 bar MAP sensor working on our 93's and he most definitely can get you set up with a good tune in your current condition.
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
350350
14
Aug 11, 2015 12:03 PM
