7000k stock PCM limit
Old Aug 24, 2005 | 03:10 PM
aBrotze's Avatar
7k stock PCM limit
I always thought the PCM was limited to 7k rpms. However , I remember a discussion on some PCMs being able to go to 7200k. Can anybody shed some lite on this ? I am bumping the 7k limit close to the end of the 1/4 and was thinking an extra 200 rpms would do the trick. Also, what exactly happens after the 7K limit is reached? I have heard that the fuel is cut.
Old Aug 29, 2005 | 10:47 PM
atljar's Avatar
Re: 7k stock PCM limit
On Obd1 cars the ECM crashes and the engine shuts off. You have to key off and restart. OBD2 cars give you a little more RPM range, but tuning in the upper RPMS is tricky
Old Aug 29, 2005 | 11:47 PM
Dave '97 Z28 M6's Avatar
That would not be good!
Old Aug 30, 2005 | 02:00 AM
smoknta's Avatar
Not to sure about the 7K myth...but I know on my 93 with tunercat I can control the rpm the fuel is cut off at.
Old Aug 30, 2005 | 10:44 PM
redcamaroz28's Avatar
You can set the fuel cut-off at however high rpm you want, but you just won't be able to rev there since there aren't any fuel/spark tables going beyond 7k
Old Aug 31, 2005 | 08:17 AM
smoknta's Avatar
yeah...I forgot about that.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
