-40* timing????
Old Nov 25, 2003 | 04:02 PM
SS RRR's Avatar
-40* timing????
This is on a OBDII LT1 car.
Had the PCM dyno tuned with a LPE 211/219 cam a few years ago and recently went with a larger cam. I know I need tuning but the problem is I just autotapped this car a few weeks ago and I was seeing mostly -30 to -40* of timing being pulled.
02's are reading over 1000mv as well. Long term fuel trim is over 15% so yeah.. the car is running PIG rich.
My question is, does the crank trigger sensor serve more purpose than to read misfires? The crank trigger harness was damaged and a new pig tail was installed yet I'm not sure if the individual who connected it fastened all wires in their proper place.
Car runs good. Just real rich.
If anyone wants to see the file, let me know.
Old Nov 25, 2003 | 04:27 PM
SS RRR's Avatar
In looking at this file further it looks as though timing values are correct but showing a negative number.
Old Nov 25, 2003 | 10:50 PM
It is just the way the tool you are using displays the timimg advance. Some tools show the - and some don't.
If you think about it, timing advance is rightfully going to be a negative number because it is BTDC. Your engine would barely or not run with 40º of timing pulled.
Old Nov 26, 2003 | 02:55 AM
SS RRR's Avatar
I appreciate the reply. I know all of about nothing when it comes to tuning or using autotap. The one that was on my car belongs to a LS1 owner. Not sure if there is a difference between LT1/LS1 autotap or if the difference is between OBDI and II.
Old Nov 26, 2003 | 11:13 AM
LWillmann's Avatar
Autotap will be the same for LT1 or LS1, but depending on the version you run I believe, it will display the timing as negative values.
Mine does for my car.
Old Nov 26, 2003 | 02:26 PM
Hey Brian..... what's up?
You might want to read this. .
From the section on spark timing:
SP (Spark Timing):
This is the spark timing. On the ScanMaster, it is shown as a positive number (actually there is no "+" sign). On some other scanners, this is shown as a negative number. Don’t panic. Just call it "advance" and ignore the negative sign.
The crank position sensor is only used for misfire detection.
Old Nov 26, 2003 | 02:59 PM
SS RRR's Avatar
Thanks!
Hey Fred,
That's good to hear. Kinda freaked me out for a bit especially since it displays positive numbers for my friend's LS1.
Thanks for the reply and I'll be paying more attention to your webpage on autotap values here shortly.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
