1995 PCM pin-out verification
Old Sep 2, 2005 | 03:47 PM
Russtebo's Avatar
I recently got a code 43 (Knock sensor). I've gone through the steps to try and find out the problem, but nothing has been successful. After further research i've found that supposedly the correct position of the wire that runs from the sensor to the PCM is D22. Mine is in D27. (The blue connector) Am i wired wrong? Can someone please verify this on their car?
Now, if I am, I want to know why I haven't gotten this code 2 years ago.
Old Sep 2, 2005 | 04:20 PM
Re: 1995 PCM pin-out verification
D22 is correct. D27 should have nothing on it. I would check it again. I think you counted it wrong. If you started counting the second row from the wrong end, 22 would appear to be 27.
Old Sep 2, 2005 | 07:11 PM
Russtebo's Avatar
Thanks for the quick response! Your site is extremely helpful as well. I'll let you know if moving the pin to D22 fixes the problem.
Update: Its fixed now. Either my car is haunted or I mixed it up on reassembly. Thanks for the help!!
jackpawt883
Jul 31, 2015 08:15 AM
88IROC_Z
Jul 22, 2015 11:38 PM
whitehooptie
Jul 22, 2015 10:25 PM
GT what?
Jul 14, 2015 10:17 PM
Bz8
Jul 13, 2015 04:46 PM
