1995 OBD1 tuning help!
Old Apr 13, 2016 | 07:26 PM
  #31
1SWT95Z's Avatar
Re: 1995 OBD1 tuning help!
Could tuning my car for speed density only fix the BLM split I have at idle?
Old Apr 16, 2016 | 03:52 PM
  #32
1SWT95Z's Avatar
Ok I tried connecting a few times with scan9495 and it is still telling me no sync with PCM. How can I determine if my usb ALDL cable is bad or working? Also the same for the ALDL port under the dash?
Old Apr 16, 2016 | 04:35 PM
  #33
I'll ask GaryDoug to take a look at this. It's his software.
Old Apr 16, 2016 | 05:05 PM
  #34
GaryDoug's Avatar
Prominent Member
1. Did you check the car's connector using the procedure I posted in #6 and #8 above?
2. You can partially test the cable this way:
Leave the cable unplugged from the car but plugged into the pc.
Start the Scan9495 app.
Switch to the Comms tab.
Set the Enable Comms Display checkbox to checked (on).
Select the right port for the cable, click on Connect, and then click on Scan.
Let the app attempt to scan until it fills up the Comms display box, then click on Stop
Examine the characters in the box. See the attached screenshot. See if the string of characters following "Engine Request" or "Vehicle Data" matches the characters following the next line that says "Bad response". The app is reading back the same characters it sends; so if they match, that means the send and receive data lines (green and white) wires are connected together properly and the cable is working at least up to the car connector.
Old Apr 16, 2016 | 09:46 PM
  #35
1SWT95Z's Avatar
OK guys thank you. I will try this out tomorrow.
Old Apr 16, 2016 | 11:06 PM
  #36
Fatdog2's Avatar
I was pulling my hair out trying to get this to work on com3,then I typed in com 4 on the #2 select port section on the scan 9495 v2-4-0 page and everything fell into place.Hope this helps.If I posted this before forgive me> I thought it was the cable to.My02.
pete53
Jun 27, 2015 09:08 AM
z28cam1993
Jun 15, 2015 07:32 AM
Hobbyguy
May 26, 2015 02:15 PM
LimitedEd1LE
May 18, 2015 01:24 PM
ksharr
Aug 30, 2002 10:58 AM
