1986 camaro TPI 305 code 34
im having a problem with a driveabilaty issue. my car will idle fine with the CEL off ,but when you give it gas it stumbles/bogs for a second then it sets a code 34 and runs ok but rich. it has only one code and i have no vac leaks .i have replaced the MAF, and both relays with no change . im working with the FSM for the car and so far havent been able to resolve the issue. i have checked the values at the MAF wire plug and i have 12v, 5v, and 2 ground circuits and no power to the burn off blue wire (checked with key on engine off).i have been thru several MAFS and even tryed the ones from 85,88-89. no luck. im asking for some knowlegable help ..any TPI gurus out there with some insight??
Jul 4, 2005 05:00 PM
carcrazyQT
Sep 17, 2002 07:54 AM
