Whats the best electric cooling fan...
Old Jul 12, 2008 | 10:39 AM
ddz28x77's Avatar
Anyone have any thoughts on what brand electric fan I should buy for my 454. The space I have to work with is 22.5"x15-16" - depth is not an issue.
Should I look for one big fan or duals?
Thanks.
http://www.intrepidgrp.com/newest.html
Old Jul 12, 2008 | 01:29 PM
Stephen 87 IROC's Avatar
http://www.jegs.com/p/Flex-a-lite/744321/10002/-1/10117
Thermostatically controlled
Manual fan switch
AC relay
Had one on my 454SS. In the winter time it never came on unless the defrost was on (AC circuit). Had no problem keeping the engine cool in the summer.
The motor failed after about 7 years and I was able to get a replacement motor.
Old Jul 12, 2008 | 02:59 PM
ddz28x77's Avatar
thanks
Thanks I appreciate it.
Any thoughts on me leaving the flex fan on and getting something like this http://www.jaycorptech.com/showprodu...7&categoryid=2
Thanks again...
Manual fan switch
AC relay
Old Jul 14, 2008 | 01:21 PM
cause4panic's Avatar
Current Draw: 26.0 Amps
Old Jul 14, 2008 | 07:27 PM
'74Z28's Avatar
lincoln Mark VII fan flows around 5000 cfm big draw on the amps though.
Old Jul 29, 2008 | 06:38 PM
Dave89IROC's Avatar
I have one off these on my K5 LT1 swap, works great, but yeah, AMP hog, runs ~ 35 A running, 55A+ on startup
anyone know the CFM of stock LT1/LS1 F-body fans?
Old Jul 30, 2008 | 10:19 AM
Rice Killer87's Avatar
Go to the local junkyard if you have one and get a set of LS1 fans. Had them on my 79 Z w/ a BBC in it and they worked fine even w/ only one hooked up !
Old Jul 30, 2008 | 11:45 PM
'74Z28's Avatar
Like 2500 CFM on high
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
CARiD
Sep 7, 2015 08:21 AM
jerrysims71
Aug 15, 2015 12:47 PM
