What is the proper coolant and water mix?
Old Mar 17, 2004 | 09:03 PM
  #16
Greed4Speed's Avatar
Originally posted by kacy
i thought water boiled at 212*
Yup you're right. I had just read a thread on thermostats and had 180* on the brain. Case of thinking 1 thing and typing another.
Piet, even w/the solution raising the BP. The additive I suggested would do this also. Then you have the fact that the more water you run the better your system will cool. No need to worry about boiling over if you never get near that hot.
Either way, if your system works properly and is adequate, you should never have overheating problems. In the 12 years I had my 70 it got in the low 200s twice. Both times were from mechanical failure of part of the cooling system. Even in 110* temps sitting in traffic it would only get to 190*. I ran it 30-70 (AF-H2O) mix and it never had freezing probs even being parked outside w/temps in the teens. It wasn't stock either. This was a 12 sec street car w/ a 350, headers, th350, 10" converter and 4.11 gears and yet the cooling system was stock.
Old Mar 26, 2004 | 09:03 PM
  #17
Green95Z28's Avatar
50/50 is the best, you can "get away" with water, but antifreeze also helps stop electrolosis (spelling?) in aluminum, and rusting in iron, if possible use distilled water in aluminum applications
Old Mar 27, 2004 | 07:01 PM
  #18
Again, that is where the additive I mentioned comes in in pure H20 apps.
I ran my car w/the 30/70 mix for 12 years w/no adverse affects.
blac94Z
Feb 15, 2021 09:43 PM
Blood type Z28
Apr 8, 2015 11:34 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
warmeck
Mar 1, 2015 08:47 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
