What is this???? located on firewall behind the distributor
Old Mar 31, 2006 | 08:05 PM
1st and goal's Avatar
Here's a picture of this lil bastard that is located on the firewall behind the distributor, anyone have any idea what it is?
There is an orange wire that is close to it that is broken off and it appears that it would possibly connect to the bottom of the connector?
http://nitrousfedmuscle.com/marcspics/wtf.jpg
Old Mar 31, 2006 | 08:14 PM
94B&RZ-28's Avatar
Re: What is this???? located on firewall behind the distributor
possibly for a tach? or mabye elec choke??
Old Mar 31, 2006 | 09:08 PM
Angelis83LT's Avatar
I think the wire for my tach is attached to a thing like that on my 3rd gen... I think.. have to check it out again at ome point.. once i take the cover off it.. But i do believe it has to do with the disty
Old Apr 1, 2006 | 09:57 AM
94B&RZ-28's Avatar
are you running a MSD coil pack? possibly the previous was?? Good luck to ya man, I had to trace back about 5 on my 68, all were dead ends so I just removed them
Old Apr 1, 2006 | 05:43 PM
Dave89IROC's Avatar
the red wire is stuck in the connector for a oil pressure sender
the other thing looks like a RFI suppressor from the original ignition setup
Old Apr 2, 2006 | 07:59 AM
Thanks, I was thinking it might be something for the old points ignition setup.
Marc
Old Apr 3, 2006 | 01:49 PM
Z28SORR's Avatar
Give the man a cigar. Back in the day, AM radio was very susceptible to ignition stactic. So this suppressor (big resister) was used to help keep things quite. This is why early Corvettes had the entire system covered with a chrome metal shield. FM radio's are not affected.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
gelbza
Jul 12, 2015 08:10 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
Slayer
Jul 4, 2015 03:06 PM
