trick flow sbc heads. what plugs should i use?
Old Feb 29, 2004 | 03:30 PM
thirdgen327's Avatar
i recently purchased and installed a set of trick flow twisted wedge heads on my 327. i need a suggestion on which plugs work best with these heads. i would call trick flow , but its sunday and i wanted to get the car fired up tonight.. any help is appreciated.
Old Mar 1, 2004 | 10:24 AM
BIGBADBOWTIE's Avatar
Im running the AC #5 plug.
This is from Trickflows web page.
Spark Plugs:
The following spark plugs are recommended as a starting point:
AC-FR3LS replaced with ac #5
Autolite-324
Champion-RC9YC
NGK-FR5
NOTE: Make heat range adjustments based on tuning results. Blower and nitrous applications will require you to run a colder heat range spark plug. Try several heat ranges as needed.
Very good head in my opinion. I have them on a my 355.
Old Mar 1, 2004 | 12:04 PM
Maldo's Avatar
Re: trick flow sbc heads. what plugs should i use?
Any updates on how the trickflow heads worked out for you
thanks
jim
Old Mar 1, 2004 | 05:54 PM
thanks for the reply, i went with the ngk plugs. much longer plug than with my double hump heads and i had to trim my headers to get them in. fun huh....! i actually just fired the car up since the rebuild and what a difference in sound alone. i switched my 327 to a full roller set up, and with the trick flow heads it really sounds so much healthier.the heads i installed were milled down to 54cc chambers and you can really hear that extra compression. i cant wait to take this thing out and see how much more umph the car has now.
thanks again for the reply. i will let you guys know how the heads feel power wise.
Old Mar 2, 2004 | 10:27 AM
JEDCamino's Avatar
What size cam are you running? I've been considering the Twisted wedge heads.
Old Mar 2, 2004 | 04:30 PM
i'll have to find my card , but with the 1.6 rockers the lift will be in the .540 range and the duration is .298..
Old Mar 4, 2004 | 05:45 AM
sleepybu's Avatar
the heads i installed were milled down to 54cc chambers...
how much did you have to take off to get 54cc's
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MadMav
Feb 6, 2015 11:02 PM
Chris Anderson
Jan 27, 2015 08:30 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
