Timing help please.
Old Feb 29, 2004 | 08:08 AM
jp2002ls1's Avatar
Timing help please.
I have a new Summit HEI style distributor: http://store.summitracing.com/partde...=SUM%2D850001R
and I need to know what I should set my initial timeing at. I don't have a timing light that tells me total advance so if anyone knows what the base timing should be please let me know.
Also should I have the vaccum advance connected to the "part vacum" port on my edelbrock carb or the "full vacum" port?
Thanks for any advice or help.
Old Feb 29, 2004 | 01:07 PM
kacy's Avatar
i believe its supposed to be hooked to the part throttle and the base timing with the vaccuum line off and pluged is somewhere around 8*
Old Feb 29, 2004 | 09:33 PM
angel71rs's Avatar
Yeah, 8 is a good starting point, then you can optimize from there. My 71 runs best with 12 initial and 36 total. I prefer full time vacuum. Idles better and gets better mileage. Ported vacuum is a child of emissions. Something to do with full time elevating combustion chamber temps and raising Nox levels, I think. But try it both ways to see what works best on your combination. You aren't going to hurt anything switching it around.
Feffman
Oct 9, 2015 05:42 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
gh0st
Aug 16, 2002 12:15 PM
Z28 97'
Aug 4, 2002 09:43 AM
