Suggestions for 305 SB?
Old Dec 7, 2006 | 07:58 PM
gross693's Avatar
I recently bought a 79' camaro for $2300 body is in great condition but the engine could use some work. What suggestions do you all have for performance ups on a budget? I was able to pick up an Edelbrock performer intake manifold and a four barrel Holley 600 cfm carburator. I don't want to spend over $1000. Any help is appreciated.
Old Dec 8, 2006 | 09:09 AM
angel71rs's Avatar
Exhaust, as in headers and good set of pipes/mufflers, would be best bang for the buck. Do you live in an area that does emissions testing? Watch out for the cam having rounded cam lobes. Mid/late 70s SBCs are infamous for factory installed cams going bad. And welcome to the board.
Old Dec 8, 2006 | 12:47 PM
mdacton's Avatar
new cam and timing set, headers and exaust....check to see if your dist. is worn
Old Dec 10, 2006 | 12:51 PM
byrons1502's Avatar
number one and cheapest upgrade is find another engine. buy an old truck with a 350 or 400 and swap it out. you can get another engine and camshaft with a gasket set cheap. the number one performance upgrade would be gears. i bet you have 2.72 and it goes 45mph in first gear
Old Dec 13, 2006 | 09:50 PM
1977maroman's Avatar
No Replacement For Displacement
Dude I have a buddy who scored a 454 for 600 bucks, big block is the best way to go for power. you could crank some serious horses especially if you live in a state that doesn't smog.
Old Dec 14, 2006 | 07:49 AM
XcYZ's Avatar
I agree. Take that 305 and dump it at the nearest automotive recycler. Any money spent on a 305 is a waste.
Old Dec 14, 2006 | 11:15 AM
gross693's Avatar
Thanks for the suggestions. I have an '87 G20 with a 350 in it would I be able to use the engine from that?
P.S. Thanks for the warm welcome
Old Dec 14, 2006 | 03:04 PM
ChevalierSS's Avatar
Any standard small block chevy should drop right in and all of your accessories bolt up without problem (assuming it is carburated).
I also think '87 blocks use roller cams, which is a plus.
Old Dec 14, 2006 | 08:18 PM
Binkz's Avatar
I think that your 305 would make a great boat anchor. For a G note you can get a pretty good 350.
Old Dec 17, 2006 | 06:15 PM
byrons1502's Avatar
drop in the 350 and enjoy, bolt the intake carb and get some headers. i just installed a jegs 3" exhaust for header with some flowmaster on a slightly built sbc and it sounder better than my bbc chevelle w 3" exhaust
Old Dec 18, 2006 | 08:12 PM
gross693's Avatar
Will do thanks again everyone
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Rittmeister
Aug 7, 2015 01:13 AM
